Question about Sony Resistance: Fall of Man
Mic problems online
When I play online I want to speak with my friends, I connect the mic and all that stuff but still I doesn't work or the other players can't hear me
any idea why?
I can hear the sound and all seems to be ok
When I play Rock Band online, my mic can be used as well as my Bluetooth headset simultaneously for communication...how do i disable the mic?
Posted on Mar 16, 2009
  • 98 Answers
If your mic is a bluetooth then it could be that your far away from your ps3 when your playing.
Posted on Oct 12, 2008
SOURCE:
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
My mic doesn't work
Go into your settings for the thing. Sometimes they will get changed. Make sure the output is set to your brand mic.
Oct 10, 2012 | Sony Playstation3 Ps3 98097 Bluetooth...
When i plug in my mic i cannot hear my friends talk but it says my mic is in and i am talking.
You used the term "plug in my mic". I assume you mean the microsoft mic and head set. one of the best ways to check the headset and mic. is to go onto microsoft live and attempt to leave someonw a voice message. during the message you will get a message that says your mic is not working. also after you finish the voice message attempt to play if back if you do not hear anything then the problem is with your microsoft head set and attached mic. if new take if back to exchange for another one. there could possibly be something wrong with the port connection on you microsoft controller.
Jul 01, 2011 | Microsoft Headset for Xbox 360
When playing online on my xbox 360, my tritton 180 universal headset works, but ppl can't hear me talk. Help.
Do you have the chat cable connected?
Is the mic turned off on the inline volume controller?
Is the Chat volume turned up on the inline volume controller?
Test the microphone on a PC by plugging in the USB into a PC and test if it works.
If it doesn't then you can ask for a spare microphone from TRITTON / Madcatz.
If the mic works on the PC then the problem might be with the chat cable which you can also ask from TRITTON or Madcatz.
Hope it helps...
Feb 14, 2011 | Mad Catz Tritton AXPRO Gaming Headset -...
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
I cant get the headset icon turned on
All you have to do is plug in the mic, go to Accessory Settings, pick the correct mic for input and output, and test whether the mic is working by talking and looking at the sound level. Then when you go online to play COD4, there should be a mic icon next to your PSN. It should light up when you speak. There is no button to push.
Dec 13, 2009 | Logitech Cordless Vantage Headset for...
I can;t get mic to work with guitar hero wii
first check that you have 4 remotes in play the remote for the mic will be the scroller and has to be used to join the band...second this may be unreliable since it came from another source but something to check a wifi connection is needed you dont have to play against someone online just be connected to wifi.
hope these resolve your issues
Dec 25, 2008 | Nintendo Wii Console
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
See all Sony Resistance: Fall of Man Questions
Sony Resistance: Fall of Man Logo
183 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
