Question about Vacuums
I need a printed wiring diagram for a 5Kva 4Kw 240volt Dunlite genset late 90's model driven by Briggs and Stratton motor.
How can I access the wiring behind the plastic that connects to the motorized head?
If your model is a DC07 as stated there is not a separate motor that runs the brushroll. The brushroll spins from a belt that comes from the main motor or goes through a clutch assembly with two belts. If it is a ball model and the wires have severed you will need to replace the wire or wires with the proper replacement parts for it to work properly. I would need your model number to determine the proper wat to fix it.
Mar 25, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
Mar 05, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
2011 mtd yardman pusher lawn mower.Need complete recoil starter assembly
order it online Im sure that the parts should be available through briggs and stratton or yardman inc
Jun 28, 2014 | Dewalt Vacuums
I need a recoil starter assembly for a MTD lawn mower 2011 with a B&Stratton 158cc 550 series engine.The model # is11A-A18M055, and the serial# is 1211KA0057
The model number that you posted does not apply to the motor. The motor series that you posted is for a vertical motor that does not match the model. Can you supply more information?
Jun 20, 2014 | Dewalt Vacuums
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
I have a kenmore canister model number 116.2645083 I need a replacement motor. I was given 2 different numbers: 1. 4147248 2. AC92FAUX200 I can find the 2nd motor, but it doesnt have the 4 wires like the...
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I need diagram of replacing on/off switch for Oreck XL2600
Manual would not, they want you to pay a service tech.
Believe this model has switch in grip,
1. Unplug unit.
2. remove screws from grip.
separate the grip halves to access switch.
3. I believe the power cord, where it enters the grip, has slip on terminals that fit on the switch. Just substitute the wires and re-assemble.
Should not require any soldering. Be careful, routing of the cord in the handle is difficult as I remember, depending on the year model, sometime in late 90s they went from a molded in strain relief to a serpentine path.
Jun 19, 2009 | Oreck XL2600 Vacuum
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
