Question about Frigidaire Affinity AEQ6000WH Dryer
Frigidaire Affinity dryer not drying, should i change the fuse and how do i get to it. this is a brand new dryer
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 1382 Answers
SOURCE: where is the fuses in a frigidaire affinity dryer
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Posted on Apr 16, 2010
  • 744 Answers
SOURCE: Frigidaire Affinity dryer not drying,
See this link and then see part number F36 for the thermal fuse location and description - verify your model number:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150159&diagram_id=1239258#d1239258
Posted on Apr 02, 2011
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Why is my Affinity dryer not heating as well as it was put new dryer hose in back just taking touble time to dry a small load of clother & I double spin the load also
Good Morning Friend,
I understand that your Frigidaire Affinity dryer is taking double the time to dry a small load of clothes. I also see that you have put a new dryer hose on the back of your appliance to try and correct this issue. I suggest making sure that you have also cleaned out the lint filter as well as where the lint filter sits. You can clean the lint filter by running it under the hottest water you can stand and using a cleaning brush, gently, to remove any build-up. You can clean where the lint filter sits with a small attachment on your vacuum. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidair affinity dryer wont start it just beeps
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
This machine takes forever to dry. It's brand new. what is going on? I checked to make sure that the vent is working properly and it is.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 11, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity AEQ6000WH Dryer Logo
206 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
