Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
The phantom just goes around in circles & gets tangled until it stops.
    Problem Solver:
  • 20 Answers
It sounds like the gear box has failed inside the unit. Causing it to not go straight anymore. Replace the gear box assembly.
Posted on Apr 04, 2011
Goes around in a circle and won't go forward was working fine untill my husband cleaned it out with tweesers
sounds like one of the motors on the wheels stop working making it go around in circle and not forward
Feb 16, 2011 | Roomba Vacuums
The washer states "Pulsating System for Tangle
Tangling problems are normally related to how the washer is loaded. Do not place a garment around the perimeter in a circular fashion. Instead drop the article straight down in a kind of 'heap', one item next to or on top of another but not layed out in a circle. Hope this helps.
Dec 31, 2010 | Avanti Top Load Washer W797
My phantom spins in circles and goes upside down what could be my problem?
It is is going in circles, it is likely a bent hose. This is common with these pool cleaners if you store your hose in a coiled position. Try laying the hose out on a sunny day and leave it there a few hours to straighten the hose. The running on the side could be a result of the debris bag being too full and heavy. The pressure could also be too high, which would cause both of these problems. Try decreasing the water flow though your cleaner.
Sep 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
The pool cleaner goes around in a circle
It could be that your pressure is too high through your cleaner or that you need to empty your debris bag. However, it is most likely a bend in your hose. Lay the hose out in the sun (flat and stretched slightly) and let it sit for several hours to undo any bends or kinks. This commonly happens with pool cleaners when you store them with the hoses coiled. If you are storing your cleaner like this, you should definitely stop.
Aug 14, 2010 | Hayward Phantom Pool Cleaner Complete with...
My Hayward Phantom pool cleaner has stopped cleaning and just goes in circles. How can I fix?
If the cleaner has no suction, check for obstructions in the debris chamber or throat of the cleaner. Also, check for hose leaks. If the cleaner has suction, but is just not moving properly and is spinning in circles, you most likely have a problem with your hose. It is a common problem with these pool cleaners getting small kinks or bends in their hoses that cause them to move in circles. If you store your cleaner hose in a coiled position, this will make the problem worse. Try laying the hose out in the sun and stretch it slightly. Let it sit for several hours, reconnect, and try it again.
May 27, 2010 | Hayward Phantom Pool Cleaner Complete with...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
I pulled my Phantom out of storage last week, placed it in the pool and it just goes around in circles. Water is slightly spraying around the little marble in the cam spin-out part but the clock hands go...
If it is going in circles, it is most likely a hose problem. Try laying the hose stretched out on a sunny day. Leave it for several hours. It may help to straighten the hose. If you can't get is reformed, you might have to replace the hose or the connection in the back of the cleaner. This is a common problem with this kind of automatic pool cleaner, especially if you coil the hose when you store the cleaner. That is never a good idea.
May 06, 2010 | Hayward Phantom Robot Cleaner without...
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
344 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
