Question about Nokia N70 Cellular Phone
Rapid discharge I cannot use the phone for up to an hour after complete charge,N70,what should I do to enjoy my nokia N70?
  • 5 more comments
  • pasgenesis Aug 05, 2008
    I amin Cameroon,africa.Not versed with all the optins you have given.what do I do next?
  • Anonymous Aug 05, 2008
    i changed the battery ,wash the whole circuite
    how can the whole circuite be washed and using what type of chemical for that?
    I have changed a thousand and one batteries to no avail.What then is the trouble?
  • Anonymous Sep 09, 2008
    rapid baterry discharge
  • fatecary Sep 09, 2008
    always hang,slow typing respons,rapid baterry discharge.
    my phone discharges fast. i need to charge it everyday
  • 35 Answers
Be sure the batteries you bought are genuine from motorola. And if it is still discharging fast, try asking motorola to reprogram your phone.
Posted on Aug 05, 2008
SOURCE:
Nokia N70 no signal problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 10, 2013 | Nokia N70 Cellular Phone
Sir ihave nokian70 just few minuts battery low plz solve my problem
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 27, 2011 | Nokia N70 Cellular Phone
Low battery
sir the nokia n70 comes with BL-5C battery this batter has a complaint it will not cover 1 year lifetime. so the best way is to buy a new BL-5C battery and charge it initially for 8 hours continuously..
Dec 06, 2010 | Nokia N70 Cellular Phone
My n70 gets easily discharge. i have change to a new battery but i still have the same trouble.
Make sure always bluetooth and camera shutter turned off.
set brightness(senser ) to minimum,
Try to charge battery after full empty of battery,
Only charge 2 and half hours maximum,
Buy a genuine battery(original).
Make sure all application closed (Minimisation of applications cause charge removal),(Press and hold menu key show if threre is any applications works on background),
Try to format phone by press *#7370# Install a good antivirus(netquin)
Jul 10, 2010 | Nokia N70 Cellular Phone
It runs low battery every 30 mins
problem can be solved.Does the phone get hot?, If yes,it is a board problem and will definitely run the battery down.
But i if no, that means the cell of the battery is very weak and can power the phone for too long, that is why it goes off.
You need to get new battery.And make sure after purchasing a new battery, you charge the battery for longer hours until it shows 100 percent charged before using it, otherwise the cell of the battery will not work properly.
Have a nice day.
Mar 19, 2010 | Nokia N70 Cellular Phone
I charge the battery of my nokia n 70 but after few minutes it shows only one point in battery icon so what i do wid ma fone?
dear,
first of all, let it charge completely that may take serveral mins or an hour.
if you see the battery after some mins it will show like this and maybe it go down when u use your cell phone... so keep it charged completely.
goodluck...
Aug 19, 2009 | Nokia N70 Cellular Phone
Unlock Code for Nokia N70
Go to Service Center and UNLOCK your Mobile Phone Device with the help of UFSX,TORNADO etc
Enjoy
Awais Shahid
Dec 31, 2008 | Nokia N70 Cellular Phone
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Key pad mafuntioning
Hi, there is your mobile dialing fault there may be inner keypad is demages. so if you can chang it, pl chang and check it. For ur second problem is phone not go on when fully discharges, at this time you have to put your mobile under charging for three or four hour, dont worry when u put mobile in charging mobile will not shows charging but there is a charging is on in mobile after one hour mobile will shows charging automatically. ok. test this and pl.reply earliest.
Oct 17, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
