Question about Sony VAIO RB30C (VGCRB30) PC Desktop
I have a soy vaio rb30, the psu died and I replaced it with a bestec equivalent, since then you can only turn on or wake the computer by turning off and on the power button on a power strip, the button on the cpu does seem to send some signal but it wont turn on until you toggle the power, any ideas?
  • 6 more comments
  • Tony Wilson Apr 03, 2011
    what i mean to say is - If the cpu is off and you press the power, nothing happens even though there is a constant green light on the psu, then pull out and plug back in the power cord or turn the power off and on at an outlet the computer starts up. If you toggle the power to the cord without pressing the power button first, nothing will happen - so the button does something at least, but wont power it up without messing with the power. I put an inline on/off switch in the cord which does the trick but is obviously not the right answer
    that sounds more like it, will get back to you tomorrow - Thanks
    Ok I tried that, i bridged the two pins and the power went off but I couldn't get it to come back on again, only with the in-line switch, when the cpu powers down the green light stays on on the psu, when you touch the power button it goes off - see videohttp://www.youtube.com/watch?v=0LmltrJac...
    I tried everything else, thanks to all who helped, I wouldn't get to this point without all the trial and error. Looks like it's the easiest thing to replace.
    Thanks for your help
  • Tony Wilson Apr 04, 2011
    Thanks for the info. I've been going crazy with this
    the power switch is working fine, it looks like it's a faulty psu
  • Tony Wilson Apr 11, 2011
    got the new psu today, installed it, works like a dream. Thanks
  • 977 Answers
Hi!
Had the same problem on one of my clients' computer... Turned out to be a faulty PSU... Just have it replaced! I'd guess same model will do - it's just a failing unit.
Anyways, double-check the connections...
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Posted on Apr 03, 2011
  • Ran Kedar
    Ran Kedar Apr 03, 2011
    Right.... That's exactly what I was referring to!
    Have the PSU replaced... It has to have guarantee.
  • Ran Kedar
    Ran Kedar Apr 11, 2011
    Glad to hear that! :)
  • 2,427 Answers
:) go to your control panel, in power options, set the power settings to desktop pc,
set turn off harddrive to never and turn off monitor to never, power management, minimal management,
in your bios you can also turn off sleep mode if you wish.
  • 3 more comments
  • Rishi Roshan Ali Apr 03, 2011
    ok i now understand what you mean.. Alright ,, lets try this, open up the cpu, see the 2 pins where the power button connects, well remov ethe power button connectors. Plug in the cpu
    (It will start up, why ? cause thats the default settings you have in the bios, on power loss resume last stat in the power settings options of the bios). Use a bladed screwdriver and bridge tthe two power pins together and hold, the system will cut off, repreat (without holding the bridge) ad you will boot up.. Chances atre you have a stuck power button replace it.
    Dont forget to rate me or whoever fixed you problem or we wont get paid.
  • Rishi Roshan Ali Apr 04, 2011
    so is it working now ? you checked the power switch ?
    well by switch i mean power button ..
    thought you replaced it ?
What graphics card can be installed in a Sony VAIO VGC-RB30 using Windows 7?
Hi Jose,
Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card. Is one of the compatible cards you can put in the system and can be sourced from
http://www.memorygiant.com/video-card/sony-vaio-vgc-vgcrb30-vgcrb30c/
Regards
Proton
Oct 02, 2012 | Sony VAIO RB30C (VGCRB30) PC Desktop
Installing random access memory in a Sony VAIO Computer
Sony VAIO VGC-RB30
Follow link and download the VAIO Users Guide. Instructions are on page 55 and 56. The manual states the maximum memory is 2GB PC-3200 SDRAM. Crucial.com states there are 4 slots total.
Sep 19, 2012 | Sony VAIO VGC-RB30 / VGC-RB30C 512MB DDR...
When I turn off the cpu with the windows shut down or sleep or power button it will only return when you toggle the power to the psu on and off, When you push the power button to restart or start up the...
Very similar problem
1. Is there a GREEN blinking light on the motherboard?
2. Check you BIOS setting. These motherboards have software installed to check voltage readings to and from the motherboard.
Apr 03, 2011 | Sony VAIO RB30C (VGCRB30) PC Desktop
When I put the plug into the PSU for my sony tower pc the green indicator light just keeps flashing. Now when I unplug the 24 pin connector from the mother board the light on the PSU is steady green. What...
the PSU has Problem . It is not supplying enough voltage to boot the PC, capacitors inside the PSU are weak or damaged. Its dangerus to open the PSU coz, Capacitors have high voltage currents. If you have the Knowledge of electronics, then open the PSU and detect the Weak or Leeky Capacitors and replace them with new one( this method is for experiment and thrill) . But the replacement new PSU is better , perfect and cheaper then repairing the psu from outside. best of luck
Feb 03, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Computer would cut off while runnig and not start. Opened it up. When plugged the mother board up, computer turned back off and I tried again and it worked.Iput it back together and would not work....
sounds like a faulty PSU first test or replace all electrical and IDE SATA leads to your hard drive if still happens replace PSU most problems come from faulty leads
Jul 09, 2010 | HP Bestec ATX-1956D 200w HP Part No...
My Sony Vaio VCG-RB53 will not turn on. Just went dead. Other peripherals on the same power source are fine. I first got a black screnn with white writing and it tryed several times to start Windows XP and...
It could be the PSU (power supply unit), one that has a fan working and where the power cord goes into. If that goes bad then the computer becomes dead as there is no power going to any of its systems. If there is any sign of life in the computer then you can try by removing the RAM and reinserting them. Or by unplugging the connector from the PSU to the mother board. But remember to plug it in in the same way that you remove it from. remember it by the color of the cables. If by mistake you turn the connector by 180 degrees then the mother board will get burnt.
Nov 02, 2009 | Sony VAIO VGC-RB53 PC Desktop
I have a gateway 506gr with a Bestec atx300 psu. I was having problems being able to turn the computer on, then one day it would not turn on at all. I can push and hold the power button, and hear the psu...
Your psu is works fine.
First open cpu cabinet and find motherbord.
Pull CMOS cell from m/b for 10 minutes.
Refix RAM Memory.
Pull procesor fan and processor clean dust from all parts.
Then fix processor fan and processor.
Reconnect ATX connector to m/b.
Remove pci cards from PCI slot then check.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
HOW CAN I TURN ON A BESTEC ATX-300-12E PSU OUTSIDE OF THE COMPUT
check on mother bord there is power on key in corner of motherbord.
Some smps has switch in back side of it.
Mar 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
260 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
