Question about Canon EOS Rebel XSi Digital Camera
Camera wont auto focus when taking a picture. it makes noise likes it doing something but nothing is happening
  • Canon Master
  • 17,970 Answers
It could well be the lens, take it off and clean the contacts on the body and lens, where they meet with a cotton swab lightly dampened with rubbing alcohol.
You have several possibilities first is that if the lens is equipped with an auto and manual switch the switch may have been set to manual or it's positioned between manual and auto focus. Failing that we suggest you turn off the camera release the lens from the body and reinstall it making sure the lens has fully locked and you hear it click into place.
Also, in this link could find several tips about
Back-Button Auto Focus Explained.
Hope helps.
Posted on Apr 03, 2011
My camera wont take a picture anymore. I push the shutter button down and nothing happens
I have the same problem - it wont take pictures in auto focus mode but will in manual focus?? Help!!
Jan 05, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My photo's are not sharp and clear. What am I doing wrong?
you could be doing nothing wrong, These cameras have auto focus and when there pas there prime, you need to get them fixed basically.
If the output is out of focus more then likely the auto focus is your issue.
Hope this does help, would be considerate if you do leave a rating or feedback before you go, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 04, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
Weird noises when it's on and zoom button noise picked up on vid
change auto focus to single focus mode,
since it is on continuous auto focus on default, it would focus all the time so you don't need to click half way before taking a picture
Mar 22, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Will not focus right, making loud noises.
Your motor may have gone bad. If it makes a loud squeaking noise, it is definitely the motor. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Feb 03, 2010 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Camera won't take a picture when autofocus is on
It sounds like you have a problem with the auto focus on the lens. The 18-135 has a focusing motor inside the lens itself. If this motor is not working, then it won't focus. It could also be the contacts (small and silver on the lens look like ball bearings buried halfway into the top part of the lens where it connects inside the camera body) or the contacts inside the camera body. These can be CAREFULLY cleaned with alcohol and a QTip or a clean pencil eraser. Just make sure you don't get anything into the lens or camera.
If the camera is over a year old, it may just be time to take it to the camera shop for a cleaning.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
Auto focus not working
The lens AF mode is not working. What lens is it you are using?
It is not a camera issue but a lens issue. Try a different lens to be certain.
Jun 08, 2009 | Canon EOS 40D Digital Camera
Will not auto focus with a smaller lens.
I had the same issue with my Nikon d60...my 18-55mm did auto focus but my 55-200mm only manual focused, i thought it might have been my camera as i heard that not all lenses are compatible with my d60 but it turned out to be the focussing motor or something that was damaged, it was making a very funny noise when it tried to auto focus with it,like a screeching sound..if this is the case you should get it repaired and looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
cheers
May 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera will not immediately take a picture.
The beep and no shutter action is usually because the auto focus is not focused. If you are using a zoom lens try backing up or unzooming a little.
Dec 20, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix 4600 Digital Camera
Camera making strange noise
Sounds like the focus mechanism, your camera will be a very light sound while focusing. this is totally normal and nothing is wrong with your camera the sound is a good thing it makes sure your photos are in focus :)
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
