When you first plug in the TV the screen lights up with a thin blue horizontal line across the center then it appears that the power to the screen cuts off and all I am left with is the green standby light blinking. I did pull the back off and check the fuse, it is fine.
  • 4 more comments
  • wcv308 Apr 05, 2011
    JVC AV-27FA44 ASA
    ....well I'm pretty good with electronics and soldering, I actually discharged the tube about half an hour ago. If I'm right the flyback transformer is the unit that is connected directly to the tube (where I discharged the tube). As for the deflection unit I'm not sure which it is....unable to get the exact service manual for this TV, though i have one for a similar unit. So is there a way to determine which has the problem without having to just replace one and hope it works?
    Im pretty good with electronics and soldering. I actually have already discharged the tube. I know which unit is the flyback, but not sure about the other. I was unable to get a service manual for this exact TV, but I do have one for a similar unit.
    Is there a way to determine which of the units is malfunctioning? It would be nice to only have to replace the one that isnt working.
    Also I failed to mention this earlier, but you may have already understood this. Once the TV cuts off and the light is blinking, the set will not turn back on unless I unplug it first, and then the whole process repeats.
    Sorry for the repeat response.
    So just to make sure....I plug the TV in, see if the clip is arcing, or actually hold it close to the hole and see if it arcs?
    OK, one last thing before I plug this in. I am supposed to plug the anode cap back in, before I plug the power cord back in, and if not, is there any precaution I should take, with the cap, to make sure I don't get zapped?
    Ok I plugged it in, I didnt see a spark or hear a spark, I did hear the....electronic stactic noise of the tube turning on (not sure if that is what you meant by guasing), but just as before it cut back off and the light it blinking again.
  • 4,889 Answers
Please tell me whats the make and model of the tv so that we can commence the diagnosis.
Posted on Apr 05, 2011
  • 3 more comments
  • eagle338
    eagle338 Apr 05, 2011
    Ok the problem you have mentioned is caused due to a malfunctioning HV circuit. Most likely to be the deflection or flyback transformer. The line accross the center of the tv before it shuts off confirms this. That being said how good are your electronics/soldering skills? I am asking coz this circuit holds potentially lethal residual voltages)around 30,000V) after the set has been unplugged. If you are not sure you can pull it off then its best to have a tech fix it for you. As my mentor says "your life and limb is worth much more than this"
  • eagle338
    That's pretty good. Yes the flyback is the one that powers the CRT. The most easiest way to test the flyback is to see if it's arcing. With the back cover removed power up the tv and see if you can notice a faint blue light emanating from it. If there is none see if there is a gassing noise coming from it. If none of these symptoms are present then we will do a more advanced test to see if the flyback is faulty
  • eagle338
    You do not have to hold close to see it. The arcing will be near the wires coming from the transformer not near the clips(anode cap etc.,) . If you cannot see anything, the see if you can hear a hissing noise coming out of it. It happens when the insualtion on the coils of the flyback is damaged
  • eagle338
    Yes you should plug in the anode cap before you plug in. Since you said that you have discharged the CRT, you have nothing to worry about. Plug the anode cap first and then plug the power cord and power up
  • eagle338
    Ok. That does not sound like it. Discharge the high voltage, remove the flyback from the board and follow this procedure to test it
    http://www.repairfaq.org/sam/flytest.htm
Balancer repair
Normally horizontal line [a thin vertical line across the center of the screen] fault with CRT based TVs is the fault with its vertical scan output section circuit. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 11, 2016 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Samsung PN64D7000 3D Plasma TV
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
