Question about HP Office Equipment & Supplies
When I scan to printer the page comes out with short lines down 1 side
  • HP Master
  • 1,915 Answers
If your printer has both an automatic document feeder and a flat glass portion for scanning, try scanning from both. If you only get the lines on one of the scans then that is where your problem is. Most common issue on scanners is a liquid paper, bit of paper, glue, etc on the Automatic document feeder glass. Clean the glass and you should be fine.
Posted on Apr 03, 2011
Problem for HP Color LaserJet 8500 Printer Black line on the left side printed page while making copy on HP. This problem occurs only while loading the page on the top tray HP 8500 printer. No black line...
This is usually caused by something on the scanner glass. Check for dried ink or correction fluid on the scanner glass. We have a short article about solving this type of issue posted here: http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | HP LaserJet 8500 Color Printer
I need to know how to send a fax from a brother MFC-295cn all-in-one printer
Hello Frank,
Sending a fax is fairly simple.
1. Make sure you have a telephone line connecting to the LINE jack on the side of the MFC-295CN
2. Check if you have a dial tone by pressing the "hook" button on the machine while the line is free.
3. Place a page face down on the flatbed scanner or in the document feeder on the top of the machine.
*Note: If you are using the document feeder, once the page is placed in, you should see "enter fax #" on the LCD
4. Enter the fax number the same way you would dial a regular phone number.
5. Press "Start"
*Note: If you are using the flatbed option, after the sheet is scanned, you will be asked if you want to scan a second page. For additionnal pages, press 1, to end scanning and start faxing, press 2
6. If the fax goes through properly you will see "completed" on the LCD
Mar 25, 2010 | Office Equipment & Supplies
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
62 people viewed this question
Seeker5211
Seeker5211
