Question about Jenn-Air JED8130 Electric Cooktop
I need a grease filter for my JennAir cook top it was purchased in 1989. I do not have a serial number anymore. Can you tell me what the part is that I need?
  • 744 Answers
See the link below, then click on the exact model number for your appliance when the page appears. Then see the specific section for the part you require:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JED8130
Posted on Apr 02, 2011
Manual for dacor gas cook top serial number M-B-06020706 model number PGM304-1S/LP/H
Try Dacor's web site
always unplug electricity before attempting to repair on any electrical appliance
Aug 23, 2017 | Dacor Cooktops
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Nov 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Jennair electic cook top
Buy whatever kind you prefer. On an open coil unit it really does not make much difference. On a smooth top, Make sure it has a flat bottom, preferably dark, not shiny. On white smooth tops avoid aluminum as it leaves grey marks.
Jun 18, 2008 | Jenn-Air Cooktops
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Jenn-Air JED8130 Electric Cooktop Logo
166 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
