Question about Kitchen Appliances - Others
Handle -leg on outlet side broken need replacement?
  • 1,536 Answers
I assume this is an electric skillet. Try gluing it back together with metal-filled epoxy (J-B Weld) - it has good thermal stability and has a good chance of adhering to the plastic used for these handles.
Posted on Apr 02, 2011
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Handle&legstands
Are you asking where to get new handle and stands for this skillet? I'm not sure I understand the question.
Sep 13, 2007 | Rival S16 Electric Skillet
I have a Kenmore electric range with burners not a flat top. The clock and the oven light work. The ovven and the burners do not work. I have reset the breaker. Could one side of a breaker burn out? Thxs
Yes, one side of a double pole circuit breaker could go bad, but unless you live in a really old house it isn't likely. Instead of just replacing the circuit breaker, $30+, you might want to check with your neighbors and borrow a multimeter to check the outlet to see if you have 120 volts on each leg of your outlet (which makes up the 240 volts you need). If you have 120 volts on each leg then your breaker and outlet are functioning.
Some ranges have an internal fuse that controls the heating elements. Suggest you go to www.searspartsdirect.com and plug in the model # off the equipment id tag (on rear panel or on oven frame) and check to see if there is a fuse or fuseable link.
Sep 09, 2011 | Kenmore Kitchen Ranges
How do i wire the plug for a 230v ac, 21 amp outlet
you will need a outlet location with two 120v legs and a neutral before you can do so. if you do not have this then go to hardware store and get a 240v breaker that will fit your breaker bucket. then wire the two legs and neutral to the location of your choice. i dont know if the plug looks like this one but it should be a 3 prong of some sort. the neutral will be marked and the two legs can go on either side. good luck.lyonhart_0.jpg
Mar 13, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a hot and neutral to work with. From a switch I want trun a 2 outlet and a switch with outlet in one box with the 3 outlets hot all the time and the switch able to control the ceiling fan. Please...
Don, you need a nuetral at the fan and the other wire from the fan to the switch is the "switch leg" The switch leg goes on one side of the switch and the hot will pigtail to the other side of the switch and the outlets. The nuetral has to go to the fan and the outlets, thus hot outlets and a switch for the fan.
Jan 08, 2011 | Cooper Wiring Devices Combination Switch &...
How do I fix a broken outer door handle on he drivers side?
Is there anything connecting the handle to the door latch assembly? Is the lock cylinder in the key hole and secured? It just sounds like the linkage may have slipped off the door handle
Aug 17, 2009 | Mazda Tribute Cars & Trucks
Can not figure out who to wire mt swith/outlet
without the right tool its going to be hard to figure out but it sounds like whom ever wired it use one of the white wires as a hot wire and one of the black wires as the switch leg once you figure the out the other black and white wire would get wired to the outlet side like a normal outlet black to brass and white to silver
if you need anymore help or questions write me and ill see what i can do
Apr 05, 2009 | Leviton 5225WSP Switch and Outlet
ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Feb 04, 2008 | Manfrotto 055NAT3 Tripod
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
