Question about Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump
I have a 30 gal 5.5 hp oil free Craftsman air compressor. It was brand new several years ago but never used it. It set in the original box in the garage. Went to use it today and when plugged in to start break in process it just hums. Got any ideas. Thanks PJ
    Scholar:
  • 133 Answers
Are you a mechanical type person? There is a fast and easy way to test the motor but it is not recommended for anyone who doesn't do this for a living. I have replaced 4 shaded pole motors in the last 3 years that did the same thing and never had a problem with a capacitor start or capacitor start/run motor. If the motor hums, it is trying to run. Try giving the stator help getting started while the motor is humming. Use a small piece of wood or soft plastic. Any non-conductor will do. Look inside the rear of the motor and you will see the field coils around the outside surface and the stator is the round thing in the middle of the motor that rotates. Use the non-conductor to start it turning in the direction it would normally run while the motor is humming. If the motor starts and runs ontill the pressure switch shuts it off, the motor is bad. If it has a capacitor on it, try replacing that first. Please let me know how this works out for you.
Posted on Apr 02, 2011
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
What kind of oil do i need for a craftman 1 hp 3 gal 125 psi compressor m/ n 921 153101?..
For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
Oct 03, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Problem with the craftsman 30 gal compressor 6 hp vertical oil free. motor or compressor will not engage, when turned motor starts for a second and sound slow then pops the breaker
sounds like you are not getting enough voltage to run the compressor if you are using an extension cord check your manual to see what gauge it should be depending on how long it is if you are plugged into a wall outlet then is the compressor the only thing that is running on the circuit if some thing else is running then you may be overloading the circuit.
Feb 24, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
My new 80 gallon Craftsman Professional air compressor's oil turned dark right away. I changed the oil and it happened again. Is there a problem? Thanks, Trevor
Problem sounds like the type of oil being used. The oil should be a gold color. It will get dark over time but not like oil in a car. Check your owners manual to be sure that the right oil is being used.
Compressors use a 30 weight non detergent oil. If you don't have a manual Go to any Sears Home and garden Department and they will be able to help you.
Feb 22, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 3 gal. air compressor mod. 921.153101, what type of oil does this unit take use?
I am sure that Sears has there own oil they would prefer you use, If not a quality brand of SAE 30 is commonly used in these compressors.
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What weight oil do I use. New compressor not used
30 weight non detergent. Sears has this oil on the shelf or you can get the same at any auto parts place.
Non detergent is the key.
Refer to your owners manual for further information
Thank you for your service.
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Dec 31, 2008 | Craftsman Air Tools & Compressors
Craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Oct 13, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump Logo
555 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
