Question about Xerox Phaser 8500/DN Printer
Phaser error ERROR CODE: 09,038,46.8515
It first came up with the error above then changed to pritnter error
ERROR CODE: 09,036,44.64163
  • bishu56 Aug 06, 2008
    ERROR CODE: 09,036,44.64163 -- Do you think this error is similar to the one that you have specified.
    We have just replaced the maintenance kit but the error is still there.
    Thanks,
    Shawn-
    President:
  • 2,072 Answers
That is an error with the ink sticks. Most likely one of the sticks is not advancing downward in the machine. Look where the sticks are loaded you will most likely find one not advancing because its twisted , cracked etc. The 46 at the end most likely means its the cyan stick, but check them all for proper movement in the ink loader.
If you have to remove them, take a screw, like a dry wall screw and twist it into the ink block and slide it up and out.
Rarely will the ink loader itself fail. If you have somehow loaded an ink stick from a different phaser model number, they are different shaped and will not actuate the switch at the end of the ink loader.
Posted on Aug 05, 2008
Errror code 37,002.37
Here's what I found in my service manual
37,0XX.xx PEST Heater Faults
An heating error has occurred. The following troubleshooting procedure applies to these errors:
37,002.47 The Left Jetstack is drawing less power than expected.
37,003.48 The Right Jetstack is drawing less power than expected.
Now my service manual was written 4 years ago. I couldn't find the specific code you listed above, but these seem to come closest to answering your error code.
Oct 24, 2013 | Xerox Phaser 8560MFP Laser Printer
Phaser 8500dn error code 13,266,44
You have either an intermittent Electronics module or a intermittent print head. Lowest cost new from Xerox is $750.
Phaser printers are expensive.
May 05, 2009 | Xerox Phaser 8500/DN Printer
My error code is 09,038,46:6774 xerox phaser 8560
Off the printer. Remove all the cables, wait 5 min and put cables back and restart it again.
or
remove the toner and put it back.
Apr 23, 2009 | Xerox Phaser 8560N Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Mar 18, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Phaser 8400 error code 37,016,43:7052
From the service manual:
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
I have the full service manual available should you need it. Thanks and please take a moment to rate this solution as fixya.
Feb 22, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 getting error -- Service Needed 37,002.47:72864
The technical error message means:
The Printhead Left jetstack heater is not drawing the expected power from the power supply.
Possible solutions:
1) Make sure the AC plug is plugged into the wall and not a UPS or surge protector. Other things such as another printer, coffee maker or other electrical devices on the same circuit could cause a sag in AC demand from the Phaser, causing it to fail it's PEST (Print Engine Self Test).
2) Verify that the wall outlet's circuit is capable of delivering the correct amount of current to the Phaser, if it does, check how many other electrical devices (aka a desklamp, radio, etc.) are on the circuit.
3) If it's out of warranty, reseat the cables from the Printhead to the Electronics Module. If it's in warranty, place a service call on the unit.
Jun 09, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser  8500/DN Printer Logo
201 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
