Question about HP Office Equipment & Supplies
My HP ALL IN ONE would not come on when press power button. Blue light does not come on either.
    Genius:
  • 1,056 Answers
#1, which HP All in One is it? Different models have different setups.
Check the obvious first.
Is the outlet it's plugged into good (plug another device into the outlet to check for power, like a radio or lamp).
If it is plugged into a surge protector, try plugging it directly to the wall outlet.
Is there a power pack module? (that's the question for the model #) if there is, is there a power litght on the module?
Please establish this first, and then we can go deeper into the problem.
Posted on Aug 05, 2008
  • HP Master
  • 6,487 Answers
Try connecting the printer on another power supply and see if it will power on if not try another power cable with same specs if you have to check if this only a problem with the cable or with the printer itself..
If still printer not powering up , have it check by the manufacturer or replace it from them if still under warranty...
Hope that helps.......
My HP pavilion dv6700 won't power on. I have a blue light at the power cord but can't power up.
disconnect the power adapter 2) disconnect the battery too 3) Press the power and hold the switch button power by 60 seconds. Then proceed in reverse and Power again and can be fix it.Of course if the problem remain test the memory from your pressing the key f2 or f9 depending of your modell in the reboot and go to the test memory.
God bless you
Mar 22, 2013 | HP Pavilion dv6000z Notebook
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
My hp pavilion dv6000 touch pad locked up, it no longer responds.
Try pressing the button above the touchpad to make the light blue, that should re-enable the touchpad again.
Regards.
Jan 13, 2011 | HP Computers & Internet
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
Laptop will not start up at all. The led next to the power jack lights blue nothing happins when i hit power.
When you press the Power button do any of the lights Flash or blink?
1.May be try removing the power adapter and battery, press and hold the power button for 30 seconds and try again.
2. Connect the power adapter with no battery
Aug 23, 2010 | HP G70-246US Notebook
My HP C4180 when powered up shows on the display screen the following: 83c00020 and does nothing else. The only way that I can power it off is to unplug the printer from the wall outlet.
press cancell (red x)button adn power button at same time then release.you will see enter special key combo on screen. then press blue button once then green button once then gray button once. it willshow some support url... then press blue button 2 times you will see reset menu.press ok on it. then press blue button 2 times agaiun you will see semifull reset. press ok.then pritner will turn off.turnm it back on it will get resolved.
Dec 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
Is there a way to shut off blue light
Hi my name is Eric,
I hope I can help you with your issue ,
Yes you can turn off the annoying blue power light, go into the menu and look for the item called blue eye effect on/off
Press the MENU button.
Press the ▲ or ▼ button to select “Setup”, then press
the ENTER button.
2 Press the ▲ or ▼ button to select “Blue Eye”, then press
the ENTER button.
3 Press the ▲ or ▼ button to select “Off” or “On”, then
press the ENTER button.
• Off : LED(Blue) will not come on when you turn the TV
on and off.
• On : LED(Blue) will come on when you turn the TV
on and off.
4 Press the EXIT button to exit.
If you feel good about my solution please click accept.
If you have more questions you can still respond,
I will reply asap
Thanks
Eric
Sep 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I need to know where the wireless switch is on an HP Pavilion ZV5410US laptop computer
Most HP Notebook PCs have wireless devices built-in. To turn on the built-in device, simply press the wireless power button on your PC which will have the universal symbol for Wi-Fi (shown here on the left) and illuminate with a blue light.
Sep 03, 2009 | HP Pavilion zv5410US Notebook
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
HP doesn't do anything
do one thing
take out the AC adapter and then take out the battery, then press hold the power button for 15 seconds and then put in the battery and try to start.
Further Queries are welcome
Feb 19, 2009 | HP Pavilion dv9000z Notebook
145 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
