Question about Bissell 9200 Upright Vacuum
Bissell Proheat 2x model number 9200 Sometimes it did not release water.Then today I unpluged it and went to a different room pluged in does not work tried different outlet will not turn on
  • 24 Answers
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Posted on Aug 13, 2008
Yes and I called Bissell and they had me take it apart found out the switch was bad also.Just in case anyone has this problem.
Thank you so much for your help
Bissell proheat 9200 won't dispense water
Check your filters. Your User's Guide should provide you with location info. Contact Consumer Care at 1-800-237-7691
Jul 17, 2014 | Bissell 2X Proheat 9200 rug cleaner
Bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
Jul 22, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Have a model 9200 that is not dispensing fluid,
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell Proheat 2X Carpet cleaner will not dispense water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 25, 2010 | Bissell 9200 Upright Vacuum
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 2X Proheat 9200 - uses lots of cleaner.
May be that the cap and valves on the bottom of the tank is not shutting like it should and letting too much to come out. You may have to replace them.
Mar 10, 2008 | Vacuums
Manual
Hi vanessaking. Here is a copy of the user's manual for it; http://www.bissell.com/images/UserGuides/9200-605web.pdf You might also wanna take a loot at this support section for this specific model for any other concern; http://www.bissell.com/Products/product.asp?catalog%5Fname=Bissell&category%5Fname=&product%5Fid=ProHeat+2X Hope that helps ! :) cheebster.
Jun 18, 2007 | Bissell 9200 Upright Vacuum
Bissell 9200 Upright Vacuum Logo
632 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
