Question about Sony Ericsson Walkman® W880i Cellular Phone
W880i tryed to flash it in boot rom mode, 2+* pressing 2 never seemed to work, flashed it but middle something happened th phone stop responding and now my gdfs is corrupt (using setoollite), the back which i made earlier seems not to work now either it wont load up. it say cf loader will no load please please help if you can give me
  • 50 Answers
Some time Sony Ericsson Software update Service will solve such problem.
I had almost same problem with Sony Ericsson W550i and SETool fail to repair it.
Then i used Repair option on Sony Ericsson PC Suite 6.001 and problem was solved.
Thanks
Posted on Apr 02, 2011
My Verykool s505 Spark stuck at boot/ continuously restarts.
First of all you will need to remove the battery from your phone to turn it off for about 30 seconds. Now Turn on the phone and Check.
is it not working still? Then Press Volume up + Home + Power button and try to Wipe data/factory reset the verykool.
Still not working? Then we have to Flash Stock Rom again with Fresh Files. (Download new Stock rom and Smart phone Flash Tool)
Open the SP Flash tool Load scatter file and Flash your phone. after Flash give it to 2min because first time normally it is slow.
Nov 22, 2017 | Cell Phones
How to flash android mobile without box
To flash any Samsung device, you need Odin for Windows or Heimdal for Mac or Linux. If by any chance your device happens robe rooted, then you can flash by the custom recovery or download Flasify from the PlayStore.
Jan 07, 2015 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
Automatic rebooting of phone
I'd suggest you do a factory reset.
If that doesn't help, flash a new ROM. But this flashing isn't as easy as it says though.
Jun 21, 2017 | Samsung Cell Phones
Flashing problem can you help me.. I follow your procedure.. but at the end it says The flashing failed. Do you want to retry the flashing? HRESULT 0x8401f141 (-2080247487) Flash: Boot rom was not d
press retry then remove the battery and usb then put back the battery, connect usb and immediately press ok while its trying to detect usb port....
Mar 17, 2012 | Nokia 2690 Cell Phone
HTC Dream "G1", locks on the boot "T-Mobile G1" screen. Will not hard reset or fast boot.
The phone needs to be reprogrammed / reflashed with the original software.
you need to obtain a rom image of the phones program and then place it on a storage card that fits to the phone.
Then you need to start the phone in boot loader mode to flash the program.
you can also try the recovery mode and see if allows you to fix the issue. more information about programming the phone here http://wiki.xda-developers.com/phpwiki213/index.php?pagename=HTC_Dream_overview_and_useful_information
if you require a rom file for the phone you may be able to find one from http://forum.xda-developers.com/wiki/index.php?title=HTC_Dream
if you are unable to get the phone to function contact your dealer or take it to a repairer.
recovery mode Hold Home button and press power button In this mode you can open shell/flash image/perform backup etc. depending on which recovery image you have on the phone. Press CALL+MENU+POWER buttons simultaneously to exit mode.
bootloader mode Hold Camera button and press power button In this mode you can install new system image (DREAIMG.NBH) from SD card by just pressing power button again.
Sep 13, 2010 | HTC G1 Smartphone
I was flashing a rom into my htc touch and i stopped the proccess when handset went white and now it is stuck on the tri colour boot loader screen and activesync wont recognise it?
It is in bootloader mode and there are 50% chances of it's survival. You can try flashing the phone again (use an original ROM instead of a cooked one, try 3 - 4 different ROMS), in case you are lucky the flashing would complete and your phone shall start again. In case the flashing doesnot complete and you are stuck in Bootloader mode, you will have to get it repaired by Service Center as the chances are that the ROM chip will need to be reinstalled.
Nov 12, 2009 | HTC Touch P3450 Smartphone
The touch pad of HTC Touch responds intermittently.
hi, its a error in the phone, I had this happen to mine. You will most likely have to sent it away for repair. Just reflash the stock ROM and make sure that you have reflashed the stock SPL if you where using hard SPL and you will be ok this site will help you flash: http://lievenvw.wordpress.com/2008/09/18/howto-flash-your-htc-diamond-or-htc-touch-pro-with-a-custom-rom/ thank you
vijay
(vote for me)
Sep 23, 2009 | HTC Touch P3450 Smartphone
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
My w880i memory card
try 2 use a card reader 2 format....
Jul 03, 2008 | Sony Ericsson Walkman® W880i Cellular...
Motorola Q phone stuck in Flash Mode
try pressing holding down the silver button in the middle of the directional pad and the power button together until you get to the master reset menu.
Oct 12, 2007 | Motorola Mobility Q Smartphone
Sony Ericsson Walkman® W880i Cellular Phone Logo
1,053 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
