Question about Winix PlasmaWave 5000 Air Purifier
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
Posted on Apr 08, 2011
I found a key and it has, winix, 5 circles, and a british flag, all ingraved in it. i want to know what the key opens! please answer my question!!!
Apparently they used for Vaultz storage boxes. It seems to be a common item. Here is a photo of a box with the key installed. I will post the link as well. You can make out the word WINIX on the key is you look carefully.
https://s.yimg.com/hd/answers/i/d95612a21fc34b5290ee92ffb5718d0e_A.jpeg?a=answers&mr=0&x=1449781209&s=aaecb71a94c8c70b96084689a3d14bda
Dec 10, 2015 | Winix Air Purifiers
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
What air filter do i buy for a replacement?
http://www.amazon.com/Winix-115115-True-Replacement-Filter/dp/B002QUZJAS
Jun 26, 2014 | Winix PlasmaWave 5000B Air Purifier
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 28, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
Nov 19, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Winix PlasmaWave  5000 Air Purifier Logo
3,008 people viewed this question
Top Winix Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Winix Air Purifier Expert? Answer questions, earn points and help others
