Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a kitchenaid aka whirlpool oven FYI the model is KGST307FBL0 It's black. anyway, the inner pane of glass on the door popped yesterday during cooking. Nothing fell on it, it just broke from the heat, I guess. I pulled the door off and took it apart to clean up the broken glass. And I see just how this thing is made. I am stunned that the The window assembly part # 9751245 is $225. I only broke 1 pane, and my question is: Do we really need both panes- can I cook without one of them? Can I buy just 1 pane for the window, or have one made? Does anyone sell this thing part for less than $200? It's outrageous the 'window' is an aluminum frame with 2 pieces of glass wedged in there- not very high tech.
  • 1462 Answers
SOURCE: Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Posted on Oct 21, 2008
Maytag317
  • 1136 Answers
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Posted on Jul 12, 2009
  • 5603 Answers
SOURCE: I had to take the door apart to clean the glass
Disassemble and reassemble FLAT to avoid gravity moving the cord.
Hint: Open door fully and put a couple nails through holes provided in the hinges to keep hinges open so you can install the door without fighting the hinge springs.
Posted on Apr 13, 2010
  • 327 Answers
SOURCE: Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
Posted on Jun 02, 2010
barkencoa
  • 3463 Answers
SOURCE: The inner pane of glass
You will find some very helpful videos on how to do this by going to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter--- CLEANING OVEN DOOR GLASS or REPLACING OVEN DOOR GLASS,
You should be able to get all the imformatoin you need here.
Posted on Dec 02, 2010
Testimonial: "Many Thanks "
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
How do I clean inside of glass on the door
Since "open the oven" feels like an obvious answer, I'm going to assume you mean the interior side of glass on a double-paned window to your oven.
If this is the case, you are going to have to break the seal along the outer and inner windows to remove them. Unfortunately, without specifics on the oven's construction, this procedure could vary. I'm surprised the inside of the glass became dirty, which may lead to you finding a bad seal anyways which may need replacing.
Oct 02, 2015 | Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
Ariston oven window pane out
Take a look at http://ovendoorglue.co.uk/fix-oven-door-glass/ whish should help explain how to remove the oven door, take off the fascia and glue the inner glass.
Oct 28, 2012 | Ovens
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
54 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
