Question about GE Refrigerators
The light on the refrigerator side doesn't work, bulb good, switch good, where does the power come from? GE model TFX25JRYD
    Sergeant:
    Champion:
  • 202 Answers
Hi... it coming from the main board at the back side of the refrigerator
Posted on Apr 02, 2011
How to get the light to come on in the freezer side by side ge profile artica?
Open the door. The door switch should pop out, the light should come on. If the bulb is burnt out, that would hinder the process. If the bulb is good, I would start with checking voltage at the receptacle and work backwards thru the door switch until I found where the power was lost.
Sep 01, 2016 | GE Profile PFS22 33" Artica French Door...
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Light bulb does not work
go to this site Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com put your model number in and you can look up your fridge,if you changed the bulb and it didn't work you could have a bad socket that the bulb goes into or a bad door switch,try pushing the door switch in and out to see if it will work or try unscrewing the bulb you might of not put it in staight or check the socket with a meter to make sure you have power there,go to that site you can look up the door switch and the socket if you need to order them,good luck
Feb 13, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
The light bulb burned out. I do not know what type and and wattage of the bulb to replace it.It is the refrigerator light bulb in GE TFX24R refrigerator. Thank you my email is endliamc@gmail.com
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Light switch appears to have failed. Light sometimes come on when the door is opened but now, it does not come on regardless of toggleing the switch.
This may be as simple as changing the bulb and not the switch. There is a good chance the bulb was loose and barely making a connection or the filament in the bulb was about to burn out. If this has been helpful please rate the solution.
Apr 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
