I have a HP1040 fax. I just change the cartridge with a new one and still showing "low ink" and will not accept any incoming fax.
  • Anonymous Dec 08, 2008
    1. ink
    Genius:
  • 2,120 Answers
GENUINE HP cartridge?
Posted on Sep 01, 2008
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
I want to retrieve a fax sent to me last year
I'm afraid your printer does not have the capability of retrieving faxes sent last year.
The only time you can retrieve faxes is when you get "low ink level" notification while a fax is coming in, where the incoming fax is temporarily stored in the printer's memory. You'll be asked to replace the low ink cartridge (without navigating away from the fax function) then hit Ok to receive the incoming fax. Other than that, you won't be able to retrieve previous faxes.
Apr 10, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Dell 964
i suggest yo contact dell, they may be able to send you some ink cartridges for testing or you could purchase some new ink (if the new inks doesnt work then its a hardware issue)
Feb 22, 2008 | Dell Photo 964 All-In-One InkJet Printer
Machine not printing
try to go a setup and option clean the cartridge
Nov 21, 2007 | HP 1040 Plain Paper Inkjet Fax
Nothing prints on the paper for incoming faxes or copying a document.
i suspect you are correct in cleaning the unit.inkjets if not used often enough the ink will clog the print head. usually the easiest solution is to keep cleaning unit it works again. other wise to clean the print head manually requires the unit to be completely dissambled. it takes a long time to fix it this way. or if replacement costs are acceptable you can replace it. i would just give it a dozen or so more cleanings.
Aug 23, 2006 | Samsung SF-335T Plain Paper Inkjet Fax
49 people viewed this question
k24674
