Question about LG Refrigerators
After installation icemaker barely nakes any ice and sometimes water may drip out from the bottom of the door where the digital display is
  • LG Master
  • 3,740 Answers
Hi and welcome to FidYa, I am Kelly.
If you would please.. Make sure the rubber fill tube is installed correctly into the ice maker water funnel This sounds like the end of the fill tube is folded over behind the icemaker. (Years of experience and been there done that.)
If this is not the problem and you have water in door, the connections for the ice maker and water in door may be reversed on the water valve solenoids or the plastic hoses are reversed. Test the water in door and see if the water goes into a glass of there is water going into the ice maker when your really want a glass of water.
Thanks for choosing FixYa,
Kelly
Posted on Apr 02, 2011
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
My Kenmore ice and water in the door refrigerator has the ice in the storage bin freezing into big clumps of cubes and the dispenser forces the bin out of position. It acts like the icemaker is getti
There may be ice forming in the water chute causing water to spill out of the chute and pour onto the ice in the bucket. Sometimes the water valve has a slow drip or is slow to shut off. the valve may need replacing. I doubt it is the icemaker but it could be.
Oct 04, 2014 | Refrigerators
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
Ice cube maker does not work what can be the poblem
first of all assure that u are getting water inside of the tray of the ice maker if you have no water then u will want to ceck in the back of the unit down the bottom a blue or white plastic piece this is called the water valve assure that u are getting water through the tube into the icemaker sometimes on some units there willbe a freeze up in the line if this is the case then you would have to defrost the line itself if your unit is getting water and u can feel ice on the inside remove the entire icemaker unit and run hot water to remove all frozen ice then reinstall your doing this becasue sometimes the gear cannot turn becuase it comes out of postion and sometimes this does make the gear go back to normal after u install you would have to wait till your icemaker once again reaches 30 degrees and then it would start making ice again if it doesnt not make ice at this point then u would have to buy a new ice maker cheapest way ton get a new icemaker is through marcone appliance parts and they will ship it to your door hope this helps
Jul 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
Refrigerators Logo
71 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
