Question about Canon PIXMA iP3000 InkJet Photo Printer
Does anyone know how to remove print head?
My ip3000 does not print magenta or yellow properly. I was using non canon ink (yes I know, it's not good for the machine) and I believe it clogged up the nozzle plate on the bottom of the print head. I would like to know how to remove the print head to see if I can clean it and maybe get my printer working properly again. Does anyone know how to remove the print head? Thanks.
  • chuckie0 Aug 15, 2008
    I have replaced the ink tanks and done the head cleaning and alignment as told to, but my printer still prints with vertical 1/4 inch strips of off color lines across the picture. how can I clear this problem? I even resized the picture smaller but to no avail.
The print head nozzles is clogged but good. None of the cleaning the machine can do will clear it. Been there and trid that. Doesn't work. The clogs need to be dissolved with a specialty clog buster and probably will need to soak at least 24 hours, maybe more. Don't deep clean any more as you will put so much in in the absorbent blotters on the inside of the printer that you will trigger an error code and not be able to print until the absorbant pads are replaced by a service tech for about $100.
Posted on Sep 02, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Magenta ink wont print
If everything else is working, except for Magenta toner; replace toner with a new one.
Jun 21, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
PIXMA ip3000 printer is printing yellow instead of red
Clean the ink cartridge contacts with a moist tissue or glass/LCD cleaner clothe. Do the same on the printer cartridge holders. Do this gently and carefully avoiding further damages to your printer and it's cartridges.
Declog print heads using denatured alcohol for an hour or two or head cleaning agents available at any ink refilling stations. You can use a suction device included in the refill kit.
Try using another cartridge of the same type by borrowing from a friend, relative or member of the family and see if the problem still occurs.
Try removing the printer driver, restart computer then reinstall driver so that the default settings will be restored. If it still exist, you can google for iptool software and try resetting it's EPROM.
If the problem still exists, you need to go to the nearest service center.
Dec 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000
canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Sep 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ink not working properly on ip3000
clean the printer so the ink will come out. Don't worry i had the same problem trust me this works!!
Hope it helps
Jul 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma 3000 not printing magenta at all
you have a blocked print head on the printer. you can try this removed the print head place it small amount of metho this could removed the blockage not always. i deak fix is to replaced the printer head .
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing
Try a new tank, there are more and more people getting bad ink tanks. HOWEVER if it is a printer that has seperate heads you might have to change it.
Sep 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
364 people viewed this question
old marine
old marine
