Question about Weedeater 2 Speed Gas Blower FL1500LE ()
I have a Weedeater fl 1500 le leaf blower that won't run wide open. It will start, but it has to remain at one half to three quarter choke to remain running. Changing the throttle opening seems to make no difference; I can change it from half to wide open and the rpm does not change. The fuel lines had cracked where they went through the tank and I replaced them and the fuel filter and that did not solve the problem.
  • 718 Answers
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
Posted on Apr 03, 2011
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
Will not run without choke on
wspring2, this is common with these machine, check you're carb adjustments. Low speed (closest to engine ) 1 and a quarter turns out, high speed 1 and a half out counter clockwise. You may have to put diaghram kit in carb. But if you have gotten a season or 2 out of it, probably not worth repairing. Sorry, hate to be the bearer of bad news, hopes this helps ya.
Dec 08, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
The pull chord is jammed on my FL 1500 LE. How do I get it loose?
Unfortunately,its not jammed,you need a new starter clutch mechanism,I have a similar problem,if you can get one from your agent/supplier its quite easy to do yourself,you should be able to download a pdf manual from the internetrgds
Sep 26, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
My weedeater starts but doesnt seem to be getting enough fuel
You can't clean the filter. You can however order a new filter with the filter attached from www.ryobi.com.
When you say it's not getting enough gas is the weedeater shutting off on you? If so your carb may need to be clean. If that's the case then report back and I can tell you how to do that.
Mike
Aug 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater 2 Speed Gas Blower FL1500LE () Logo
1,293 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
