Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
My GE Profile Dishwasher Model pdw7880n10ss does not clean. Food sitcks to the dishes and food is at the bottom of the dishwasher when the cleaning is finished. It has not cleaned from day one. I have had GE repair men here a few times but it never fixes the problem for any length of time.
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
Dishwasher won't clean?
check to see that the jets of the spray arms are not blocked. Sometimes small pieces of food get into the arms and block the spray so it doesn't clean the dishes well
Feb 29, 2012 | GE 24 in. Profile PDW7800 Built-in...
Our Ge profile Dishwasher is not cleaning the upper level dishes, mostly glasses and coffee cups. The insides are bumpy with dried on food. We have cleaned the bottom filter.
heatman101
Oct 24, 2010 | GE 24 in. Profile PDW7800 Built-in...
Food is stuck in the bottom wand holes
I personally use a metal croquet hook to pull debris out out of mine
Jul 22, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Some of the dishes and glasses are not coming clean
Either the nozzles on the spray arms are clogged, or there is not enough water pressure spraying.
You can clean nozzles with tooth pick
Jun 23, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
264 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
