Question about Dell Computers & Internet
How will i fix my laptop [dell d600] with a charging problem, the problem is when i connect my adapter it will not going to power on but when i take the battery to another same laptop it work if return it back and i have check the adapter is OK . pls help me.tanks
    President:
  • 3,278 Answers
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, could be a heatsink problem. Remove the heatsink and apply new thermal paste or the motherboard may need replacing. Leave it to an expert if you are not familia.
Hope this helps.
Posted on Apr 03, 2011
Hi , I have Dell Latitude D600 Laptop, it is working fine but a few days ago , it gave an Error on Boot Screen "Unknown AC Adapter...." while there has been no change in Adapter , Battery or any Hardware....
The Adapter should be able to run the laptop and keep the battery charged. Take adapter to a shop and have it checked. If good then the connector where it connects to laptop is probably bad.
Aug 18, 2010 | Dell Latitude D600 Notebook
My dell latitude d600 motherboard has charging problem what's the solution to it
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 25, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
My dell d600 been shorted after using defective charger
try connecting a known good ac adapter if fails then remove battery then try it again if still fails then replace the motherboard.
Oct 14, 2009 | Dell Latitude D600 Notebook
D600 Powers up via Adapter / Batteries good / Never charges
This is a motherboard issue. Go to Dell's website and click the Technical Service link ...
http://support.dell.com/support/index.aspx?c=us&l=en&s=gen
You can check to see if it is still under warranty and depending on whether it is or not, proceed from there.
Any Dell Certified Tech can easily replace your board for you in a matter of about an hour.
Jun 12, 2009 | Dell (04U621) for Latitude D600, Inspiron...
I have a Dell Latitude D600 laptop whose USB port is being used to charge the battery in an iPod Shuffle music player. The laptop shuts down after about thirty minutes of inactivity, preventing the iPod...
You can use a powered USB hub to charge your iPod, MP3 player etc. without connecting to a laptop's computer USB port.
Just connect the mains adapter to the USB hub and then plug your iPod into the hub for as long as you need.
You can also use this hub for your computer/laptop when you need extra USB ports..
Jan 10, 2009 | Dell Latitude D600 Notebook
Dell Latitude Notebook D600
the laptop probably overheated.
I would get a cooler for the laptop they sell them at wal-mart or stores such as that one.
It's a small thin table like that the laptop sits on and it has 2 fans pointing up at the bottom of the laptop.
Unplug the power supply then hit the on button and try it if it don't work unplug the battery then try that.
Happy Holidays
Dec 27, 2008 | Dell Latitude D600 Notebook
Dell D600 laptop
If you've tested the power supply and battery, then the only thing left is a motherboard component. The problem will either be with the DC jack or the power management system. First check to see if the jack is loose or noticeably broken. If not, then it's going to be the power management chip. The pm chip controls and regulates the power input, switching from AC to battery, and the charging. With the pm chip, the motherboard will need to be replaced.
Jul 29, 2008 | Dell Latitude D600 Notebook
AC popwer adapter type cannpt be determined
It is a pretty common failure, the power connection to the motherboard is cracked or broken and the Motherboard is no longer detecting the AC adapter.
Many places on Ebay advertise power jack repair service for about $100.
I also found motherboards for the D600 on ebay for about the same price. I chose the new motherboard option.
Of course, if the system is under warranty, contact Dell for repairs.
Jul 06, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Apr 12, 2008 | Dell Latitude D600 Notebook
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
