Question about Garmin nuvi 1200 Car GPS Receiver
Garmin nuvi 1200 wont turn on even though power source working
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
SOURCE: garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Posted on Feb 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: Garmin Nuvi 1250 has a dim screen when plugged
I would venture a guess that the cable you are using in the vehicle is not a genuine Garmin cable. The units are very sensitive to voltage.
Anything under approximately 10 volts - the Garmin assumes it is plugged into a USB port (Active Cradle)... not a vehicle... and it dims for quicker charging.
Switch to a Garmin OEM cable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 19, 2010
SOURCE: the unit will not turn on, even when plugged into
Have you checked the fuses in the power cable? There is a reset button under the front bezel. Try pressing that to see if your unit comes back to life too.
Cheers
Posted on Jul 19, 2010
  • 10865 Answers
SOURCE: Hi,
Hi Louise. Carefully pry the frame off from around the screen. It is thin and delicate so work carefully and use your fingernail. Once you have that frame off you will see a reset button. with the unit on, push the reset button. This may solve your problem, in fact it probably will. But, if it does not, go to Garmin.com and see how to mail it in for a repair. J.
Posted on Aug 02, 2010
Testimonial: "helpful but i still can't find the button and I pried off the silver frame. I may be missing somthing."
Tip
Garmin Nuvi 1200 Manual Download
Download Garmin Nuvi 1200 Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Manual for your Garmin Nuvi 1200 GPS?
Would you like a digital copy of the Garmin Nuvi 1200 Users Guide for easy searching of terms and quick reference?
The Nuvi 1200 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Webupdate
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Tip
Download Garmin Nuvi 1200 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1200 GPS?
Would you like a digital copy of the Garmin Nuvi 1200 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1200 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1200 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 1200 Hard Resetv
My garmin will not turn on and its fully charged
The reset button fixed the power problem. Thank You, Thank You!!!!
Feb 09, 2009 | Garmin nuvi 350 GPS Receiver
Tip
I hope that helps.
on May 14, 2010 | Garmin nuvi 1200 Car GPS Receiver
Tip
I hope that helps.
Tip
Garmin Nuvi 1200 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
Garmin Nuvi 1200 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1200 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1200 series GPS unit.
I hope that helps.
Garmin nuvi 1200 Car GPS Receiver Logo
303 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
