Question about RCA RP2612 Personal CD Player
My rca cd player displays "reading" but finds no track or no disc
Jexx
  • 148 Answers
SOURCE: CD player will not read any disc
Try cleaning the lens, best way is to open it up and use rubbing alcohol (the purer, the better) with a q-tip. Wait for it to dry, then test it. If that doesn't work, you'll most likely need a new pickup. This might be of interest to you: http://www.repairfaq.org/sam/cdfaq.htm#cdlasdlife
Posted on Apr 21, 2006
SOURCE: CD player can't find the disc.
Hey man, I had the exact same problem with mine. What you do is take off the top cover which has 2 screws on top and 3 on back side of top. You'll see where the two parts come together to grab cd and spin it. Well, you should also see a little "eye" lens that actually reads the disc. Clean this off with windex or some time of cleaner. Bam, It works.
Posted on Nov 24, 2007
  • 5 Answers
SOURCE: DVD player won't work
Sometimes this is a dirty surface on the Disk. Watching it with a soft cloth and non-abrasive 'gentle' dish soap can help. At least, that's what Netflix tells me to do with them.
If it's happening on EVERY disk, and all you're playing are commercial, new, pre-recorded DVDs, then there's more things to try. Some links from reputable sources:
http://www.techlore.com/article/10478/
http://www.ehow.com/how_2036277_fix-error-dvd.html
After all that fails, it's probably time to change the DVD drive inside the player. Sometimes this is easy, sometimes not. :) with the DRC 630N, this would be more in the 'not' arena. :)
Of course, if you have a valid warranty, then when you're left with no solutions that don't void the warranty, you have to decide whether to try to pass it off to the warranty holder for repairs.
Posted on Apr 03, 2008
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
rscheutz
  • 54 Answers
SOURCE: RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Posted on Mar 22, 2009
RCA 5 disc Changer RS2600 stop reading the cd and and shows "no disc"
The reading eye is most likely dirty and doesn't see the disc clearly. If you can clean it with alcohol on a long QTip, you might get it work again for a while. Dirt & dust are the worst on the opticals. If you can clean it yourself great. Many can't be done without taking the case cover off.
Nov 24, 2012 | Audio Players & Recorders
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
When I try to play a CD I get an "err" message. Using store-bought CD's, not ones that have been copied. I have the Emerson PD6559BL portable CD player Love this CD player so I hope you...
Extract from your cd player manual:
"This CD player can play normal CDs p/us CD Recordable (CD-R)
and CD Rewriteable (CD-RW) discs. However the playability of CD-RIRW discs
may be affected by the type of software that was used in 'ripping' the tracks from
the original discs and 'burning' the tracks onto the blank media. Playability may
a/so be affected by the quality and condition of the blank media you use for
recording. 100% compatibility cannot be guaranteed, this is nof an indication of
any problems with your player."
So try to burn the disc with another software or buy different CD-r.
You also want to make sure that you Burned the tracks as audio files and not MP3 file, because your player can not read MP3s.
Hope this helps.
May 27, 2011 | Audio Players & Recorders
When recording disk reads repair
"REPAIR"
Because the disc was left in the unit after recording and the power plug was unplugged later, the track number and
recording time data have been cleared without being recorded on the disc.
While "REPAIR" is displayed, the track number and recording time data are repaired by tracking the recorded area. Further
recording or finalization is possible when the display returns to the previous condition. Tracking the recorded area takes about 40 minutes if the disc has been fully recorded.
Jan 29, 2011 | HHB CDR850 CD Recorder
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
I have the panasonic DVR-255. after about 20 months of recording on DVD-R discs it reads some un-finalized discs as unreadable, won't finalized some discs that have just been recorded (displays...
With use, the laser tends to weaken. It is possible that it has reached the end of its lifespan. It is also possible that with use, the tracking alignment has drifted off specs.
You can call Panasonic to find out where their service rep is located for you to have a quotation for repair. If it is only tracking alignment that needs to be re-set up, the repair cost would be an hour or two for the work done. If the laser is defective, then the repair will be fairly expensive.
Jerry G.
May 26, 2008 | Panasonic Televison & Video
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
RCA RP2612 Personal CD Player Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
