Question about Vizio L32 32 in. LCD HDTV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging for several hours and replugging. No previous problem like this, set maybe 2-3 years old.
  • 1 more comment
  • Anonymous Aug 13, 2008
    Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
    Steve
  • jwellsgnr Aug 13, 2008
    Thanks much. I found that the vendor I purchased the set from has a satisfaction guarantee, they offered to give me a full refund for the set, which I accepted. Problem solved, No more Vizios for me. I'll replace with a Samsung.
  • Anonymous Mar 22, 2014
    power on but no other response from buttons
Steve
Posted on Aug 13, 2008
Vizio 55" smart tv e552vle no power or standby light!
Have you tried un plugging the TV for 10 minutes and seeing if that clears the lock up? This is a software issue I'm sure.
Mar 23, 2017 | Vizio L32 32 in. LCD HDTV
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Jan 30, 2009 | Vizio L32 32 in. LCD HDTV
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
VIZIO L32
my tv goes in and out on it's own geedevil
Feb 28, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
316 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
