Question about Toshiba Satellite M505DS4970WH (PSMLYU008002) PC Notebook
My wireless network will not turn on, i switched it to on but its saying that a network isnt turned on how do i turn it on so that i can get wifi
    President:
  • 1,623 Answers
Have you got a wireless router? Please reply with make and model of router and windows version. click on start and then press the right mouse on my computer or computer and click on manage then click on device manager in the top left window then click on the + next to network controllers and reply here with what is listed
Posted on Apr 02, 2011
Geekman
  • 32281 Answers
SOURCE: wireless networking
This message refers to your Access Point/Wireless Hub Router. These devices require to be configured to communicate to your Gateway laptop as well your wireless LAN card on the laptop.
Posted on Nov 16, 2008
  • 89 Answers
SOURCE: Where's the switch to turn on wireless networking?
The wireless switch is on the front bottom of the laptop. It should be blue when ON and red when OFF
Posted on Aug 02, 2009
siddiqs7
  • 10 Answers
SOURCE: i am not able to
This notebook goes with Dell WLAN utility to manage wireless connection and windows has default utility as well you can configure any one of it, if you want to use the windows default utility then you have just remove the Dell WLAN utility from the startup .
and also you can update the drivers though LAN connection
Posted on Aug 13, 2010
fix4issues
  • 95 Answers
SOURCE: My computer suddently started saying
Go to device manager>uninstall the wireless driver and restart the computer,check if it works ,still you have the same issue can download the wireless driver from the link - http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1513
Good luck...
Posted on Sep 30, 2010
MayeresJnot
  • 74 Answers
SOURCE: wifi switch is turned on however, when i try to
Turn your computer completely off. Turn it back on - and your wifi will reset itself. Even though it is completely on, sometimes you cannot turn the switch on, since it has locked itself off the network.
Posted on Nov 15, 2010
If i disabled wifi how to i enable in a dell laptop?
The same way you disabled it, there should be an icon on your taskbar for enabled and disabled the WLAN switch. If there isnt you need to go to control panel and go to networks, enable wirless router, search for networks etc. If that does work then you have to go into control panel, change wireless settings or change internet settings and find it that way.
Feb 07, 2011 | Dell Inspiron 1525 Laptop
Wifi switch is turned on however, when i try to search for a wireless network i get a message saying that i need to turn on my wireless switch
So I understand that your wifi card doesn't work?If that is correct go to Toshiba site and check their support-from the other computer-of course.If card is dead, you will need usb wifi.
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
I don't see any WiFi connections in my computer (Windows 7) and WiFi indicator infront of laptop does not lit. Troubleshoot shows "Wireless capability is turned off". The switch in front of PC is turned on...
First, turn the wireless switch OFF and switch it back ON
(make sure sure that there is a BLUE light on the wireless indicator)
then press Fn+F5 (this will ENABLE the wireless capability of your computer)
>Try to detect wireless networks
>comments suggestions ratings and violent reactions will greatly be appreciated
Sep 23, 2010 | Computers & Internet
My wireless network adapter isnt on
If there is a WiFi switch at edge of laptop turn on. Open up network connections, find your adapter and right click on it. and select Enable.
Feb 12, 2010 | eMachines M5405 Keyboard
Not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Feb 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do I turn off WIFI on Acer 5720 and use ethernet cord
If there isnt a button on the laptop to switch it on and off, then the easiest way to turn it off is to disable the wireless network adapter.
To do this, open Control Panel and double click Network Connections.
This will then show your wireless and ethernet adapters as icons.
Right click on the wireless adapter and then select "disable".
Your wireless adapter should now show as disabled.
If in the future you want to turn it back on, do the same again but select "enable".
Sep 22, 2009 | Acer Aspire 5720-4230 Notebook
Wifi isnt working the lights not on what do i do
See to it that your Wireless LAN is installed in your LAPTOP correctly, at this point if your LAPTOP have Wireless LAN and not installed properly cannot connect to the network & even your network icons does not appear, its useless.
Go to your Control Panel and and select icon SYSTEM then go to DEVICE MANAGER, you can see their your WIRELESS LAN device is working properly and if not install it using your Utility Disc of your LAPTOP, hope this might help you, good luck!
Jul 29, 2009 | Toshiba Satellite A15-S127 Notebook
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Toshiba Satellite M505DS4970WH (PSMLYU008002) PC Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
