Question about Maytag Washing Machines
PAVT244AWW files but does not agitate. Motor hums. Can turn to spin to empty
  • 10 more comments
  • davelisabloo Apr 02, 2011
    If there is an issue with the pulley why does the drum empty and spin during the spin cycle?
  • davelisabloo Apr 03, 2011
    Not sure if you got my previous comment. If there is an issue with the pulley why does the spin cycle operate correctly?
    The washer fills with water and does not agitate. I can turn the dial to spin and the drum spins and empties. I by passed the switch and the drum spins. If the drum empties then the pump is working correct? The washer just does not agitate. I also removed the belt let the drum fill and the motor still hummed during the wash cycle. Is there a better way to isolate transmission problem?
    I removed the agitator nothing broken. During wash cycle the motor is spinning with the belt off but belt does not move when reinstalled.
    I am confused. The motor works during the spin cycle and also is spinning during the wash cycle with the belt off. When belt is installed it hums and the belt does not move. Something is binding. If the water empties during the spin cycle I would think the pump is functioning.
    Isn't the spin cycle a load? Wouldn't a working spin cycle indicate the motor is OK?
    In spin mode the drum stops spinning when the lid is opened
    I by passed it. This machine agitates with the lid on.
    I meant lid open
    No, the machine starts and stops the spin cycle when lid closed and opened
    Not sure what to look for there? I have a voltmeter are you looking for voltage to the motor. Are you thinking the agitate speed is burned out?
    Across what wires?
  • 4,323 Answers
Hi
When the washer will wash and wont drain or spin the issue is caused due to either of these two things...the lid switch or something clogged in the drain pump assembly...First check the lid switch assembly, you can also take out the switch and try to jump start the lid switch...if the washer spins then replace it if it does not then check the drain pump assembly. As it washes fine so I believe the control and motor is fine. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 03, 2011
  • 7 more comments
  • Daniel Scott
    Daniel Scott Apr 03, 2011
    Hi
    Is your washer spinning fine? Issue is only with agitating and not spinning correct.
    If it is spinning fine and not agitating then it might be an issue with the Agitator Auger and Post Assembly, the assembly might be loose or disconnected. Inspect if the agitator is broken, remove the softener dispenser and then use a socket with a 10 inch extention remove the existing screw. Please check the video---
    Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Alright then replace the motor it is bad as even the hum sound indicates a bad motor that should be replaced
  • Daniel Scott
    yup because when you put the belt on it wont work as then you are giving it a load
  • Daniel Scott
    One thing....what about the lid switch? Have you checked it already??
  • Daniel Scott
    Yeah thats fine but did you try to jump the switch or have you checked it with a voltmeter
  • Daniel Scott
    so dont you think its the lid switch that is bad
  • Daniel Scott
    Test the motor with a voltmeter
  • Daniel Scott
    Yes right....you can check for 120vac
  • Daniel Scott
    Please read this link to test the motor
  • 2,382 Answers
Hi, the motor hums because the motor or transmission drive pulley may be worn and unable to turn the drive belt which will inturn not make the washer agitate. If so, replace the pulley.
Posted on Apr 02, 2011
  • Tunde Autos
    Tunde Autos Apr 03, 2011
    It is possible for the motor to turn without the belt turning because it is broken or due to a frozen pump pulley.....
Washer won't agitate. New transmission...new timer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Feb 13, 2010 | Kenmore 24832 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Oct 27, 2009 | Washing Machines
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
