Question about Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit
I frequently lose the satellite signal to my Sportster 5 Sirius radio. Sometimes I lose it 2-3 times per minute; sometimes it goes 3-4 minutes between signal loss. This happens with the same radio whether it's in my wifes vehicle, or in my vehicle. The connector to the docking cradle is clean with no bent wires or connections. CAn this be fixed?
  • 20 Answers
You can get service on this issue at ebay item# 360454042820
http://www.ebay.com/itm/
360454042820
Posted on Jul 08, 2012
5 Suggested Answers
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Same problem in RI too. Acquiring signal stays on the screen 24/7. My husband has the same Sportster. When I plug his into my car docking station, it works fine. When I plug mine in, it says "Acquiring signal". Does this mean my radio is dead?
Posted on Jan 06, 2008
SOURCE: Sirius Sportster 4 Problem
sell it or so many of the units run into this problem and nobody knows how to fix it.
Posted on Jan 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Can't get XM channels
Goto sirius.com. You will need to access you account and find out if your radio is upgradeable for XM channels. You can find that out once you try to add xm to your account.
If it isn't you can get a free or a discounted radio from them to do it by calling customer service up. They do that for existing customers.
Posted on Jan 17, 2009
noobcybort
  • 199 Answers
SOURCE: No sound from Sirius Sportster SP-R2R satellite radio
Hello there !
I suggest you fix it don't through it yet ,I want you to change this chip .
sound IC( Amplifier ) it could be damaged or something is loose inside .
good luck
Posted on Dec 08, 2009
Losing signal on sportster 5 Tooth on bottom appears damaged can this be repaired
take it to radio shack and ask them, they may be able to help you find a replacement
May 20, 2010 | Sirius Sportster 5 Satellite Radio...
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
Acquiring signal
My wife replaced the car kit.
The sportster itself was fine, what fixed the problem was replacing the cradle.
Now the second one has taken a dump.
May 21, 2008 | Sirius Satellite Radio Sirius Sportster...
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirus radio
I had to replace my Sportster because it was overheating and caused it to loose signal.
Jul 12, 2007 | Jensen JXM900CMB Satellite Radio Receiver
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius sir-pnr1
I'm having the same problem and all they reccommend is unplug the unit from the back for ~2 minutes and then plug it back in and power up.
Jan 06, 2007 | Sirius Satellite Radio Sirius SIR-PNR1...
Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Logo
217 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
