Question about U-Line Icemaker
Ice maker thrmostat problem
Was it your thermostat that was staying on and melting ice? I have this problem and I read what you did can you help me? Chris
  • chrisbernacc Sep 17, 2008
    had mine replaced because it was over filling with water and freezing all over the new ice cubes. Some of my cubes were stuck in the tray and when I had it replaced I saw that the tray had caroded from??? and that is why the ice couldn't pass out. When is was getting stuck more water would come in to take the palce of the ice pushed through. But it would overflow for the ice that was stuck. Than freeze and stick all the ice together. Big mess. Had it changed out with a new ice maker and all is good. I watched and it looked simple. Just a few screws.
    Problem Solver:
We were told there are not thermistats only thermistors that we replaced with the new circuit board.
Posted on Aug 08, 2008
Once full, ice melts and then doesn't start making ice again until bin is completely empty
There should be a temperature sensor (thermostat) close to the top of where the ice comes out of. This determines the height of the ice in the bin by controlling a call for cooling/making ice. This thermostat may be sticking, or is not sensitive enough to read the drop in temperature of the depletion of ice.
Feb 27, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Ice maker not working
Is water getting into ice tray? If not, check the water line feeding unit. If that is ok then check the solenoid that controls water flow into tray.
If water is frozen in tray then anomaly is caused by the mechanics of ice maker. If the ice melt mechanism does work the ice will stay stuck in there. Caused by broken heater element in ice maker or a defective thermostat in ice maker that turns the heater element on. Or it could be a defective motor in the cam that sets up the sequence of events.
Easiest fix is to just replace entire unit from ebay for about 40 bucks.
Nov 22, 2013 | GE Refrigerators
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Stays in defrost too long. ice in the ice maker melt together. drips water inside the frezzer, changed the defrost thermostat & the mother board witch has the defrost timer in it. what is the ohms...
how is the food?is the ice cream getting soft? are you just having problems with the ice melting?you could have a bad water valve,water could be leaking past the valve,overflowing into the bin and will drip down,with the heater it's gonna work or not work when it should,there's a heater in the ice maker also
Mar 20, 2010 | Hotpoint HSS25GFP Side by Side...
GE side by side refrigerator with automatic ice - ice clumping
Most likely happening during defrost. Replace defrost thermostat
Nov 17, 2017 | GE Refrigerators
We have the Kenmore 106.5703.601 side by side with an ice maker. We lost power for a whole day. The power is back, but the ice maker does not dispense ice. Water is dispensed through the door fine, and...
I think if you unplug the ice maker and remove it from the freezer to let the ice melt and dry out the Ice maker may start working again once you put it back in the refrigerator. If not we will need to check the thermostat inside the ice maker. Try that first and let me know the results. We will get it working I just need you to do this step by step until I locate the problem. But until the ice maker is dried out I cannot see if the thermostat will call for water when plugged back in. Let me know, Sea Breeze
Aug 16, 2009 | Kenmore Refrigerators
Ice maker is not making ice
hello. i can help.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Jun 25, 2009 | Sub-Zero 245
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
U-Line Icemaker Logo
90 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
