Question about Metra 99 9104 99 9104 Stereo Installation Kit for 06 Audi A3
My Audi Symphony ll goes into SAFE mode everytime I switch the ignition on even AFTER entering the safe code correctly and driving the car with the radio on, it will go into SAFE mode upon every ingnition start so I am therefore having to enter the safe code everytime I get into the car. Why is this do you think?? P.S I had a parrot MK9200 Handsfree wired into the car a week ago, but this is working fine.
  • KCAS Apr 02, 2011
    Thanks a lot for your help, I will mention this to the guy that fitted the handsfree system as it must have be something he's done :(
    Scholar:
  • 116 Answers
It sounds as if you have dropped the constant live feed to the unit somehow. The constant feed keeps the power fed to your unit/system for memory backup. This also includes your code. The code must be used and entered when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
Hope it helps
Posted on Apr 02, 2011
Testimonial: "Thanks a lot for your help, I will take the car to the guy that fitted the handsfree and tell him."
Hi.2005 Audi a3 stereo fault.stereo goes to to safe mode every time i turn engine off any ideas?
You have either lost the "keep alive memory" 12 volt power feed to the radio that is always hot even with the key is turned off or you have a defective radio.
Jul 15, 2016 | Audi Cars & Trucks
What are the steps to enter radio code for Audi A2 2008 Model?
I'm not sure which model you have but these are the instructions for Symphony 1.
I'm not sure if this also applies to Symphony 2 (which has a built in single slot 6 CD changer)
Switch on - display shows SAFE as you indicate
Press and hold TP and RDS buttons at same time until 1000 appears
Release buttons (dont touch again or 1000 will be entered as the code)
Using station select buttons 1 to 4 enter code. Use button 1 to select first digit of security code, button 2 for second digit etc (buttons 5 and 6 cannot be used)
Once code is entered press TP and RDS buttons together and hold until SAFE appears
Release buttons and a radio frequency will appear in the display
Job done
If you accidently enter the wrong code the word SAFE will start flashing. You get ONE more chance to go through this procedure and enter the correct code.
There is a more complicated procedure to go through after this with one hour time delays between attempts
Let me know how you get on!
Jan 10, 2015 | Audi Cars & Trucks
Skoda fabia 04 plate ive replaced after market stereo with the original skoda symphony one i put the code in and it works however everytime i restart the var it goes into safe mode
You may have the 'backup' supply line switched with the ACC/IGN supply line.Backup has permanent 12V supply. ACC line only have 12v after you turn the key to position 1 or ACC.
Jul 20, 2014 | Cars & Trucks
Hi I got a 2002 audi a6 the radio displays safe but even if I keep scan and rds buttons pressed nothing happens.wat is the solution
it depends on year of car and make of RADIOHERE IS THE SETTINGS FOR A 2002 AUDI A6 Quattro V6 2.7L Turbo (APB) engine code
For the Audi Concert Radio
YOU STILL NEED YOUR RADIO CODE TO ENTER THIS!!!!!!!!!!!! tell me if this work for you
Entering Anti-theft Code
The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
1. Turn on radio. The radio display shows "SAFE".
2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
5. The radio should unlock and be usable shortly afterwards.
6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
7. If you lose your radio code, contact your Audi dealer.
Note: Some European market Concert radios have a TP button instead of the FM2 button, so the description above with those units would require pressing the TP and the RDS buttons simultaneously.
Dec 03, 2010 | 2002 Audi A6
My radio is in 2 SAFE mode on my 2004 Audi TT. My mechanic had to disconnect the battery to replace some parts on my car. when he turned the car on the radio was in 1 Safe mode. The code in the manual he...
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Nov 20, 2010 | 2004 Audi TT
I have a 2001 Audi A6 symphony 4b0 035 195A, auz5z4y0144932 with safe mode on can anyone retrieve the unlock code for me, I bought the car and the guy didn't give me the code, thanks!
The radio code is only obtainable from an Audi dealer. They would have to e -mail Audi with the vehicle details and the radio serial no to get the radio code. They would then enter the code for you.
Jun 13, 2010 | 2002 Audi A6
What are the instructions for entering radio codes for a 1998 Audi A8?
Audi Bose Radio g_tri90.gifAudi Gamma CC Radio g_tri90.gifAudi Delta CC Radio g_tri90.gifAudi Concert Radio g_tri90.gifAudi Symphony Radio which one of the above is your system?
Mar 26, 2010 | 1998 Audi A8
My audi a6 radio has a SAFE message in the screen what it does mean?
Did you disconnect the battery or run it down? This message means you must enter the correct code. If you do not have the code contact your Audi dealer. I'm not sure which model you have but these are the instructions for Symphony 1.
Switch on - display shows SAFE as you indicate.
Press and hold TP and RDS buttons at same time until 1000 appears.
Release buttons (dont touch again or 1000 will be entered as the code).
Using station select buttons 1 to 4 enter code. Use button 1 to select first digit of security code, button 2 for second digit etc (buttons 5 and 6 cannot be used). So, say the code is 5238, you'd press '1' five times, '2' twice, '3' three times and button '4' eight times.
Once code is entered press TP and RDS buttons together and holde until SAFE appears
Release buttons and a radio frequency will appear in the display.
There is a more complicated procedure to go through after this with one hour time delays between attempts.
Curtorsey Audi Owner's Club:
Dec 10, 2009 | 2006 Audi S4
I have a 1999 Audi A6.
Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  2. Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 02, 2009 | 1999 Audi A6
Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
Sep 18, 2008 | 2000 Audi A6
Metra 99 9104  99 9104 Stereo Installation Kit for 06 Audi A3 Logo
381 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
