I get an unknown signal on my hp4260n when plugging in my ps3 via HDMI
Press and Hold the power button on your PS3 when turning it on
after three beeps let go
your TV should now display have reset itself to a failsafe resolution (480i or 576i)
set it up from there to the recommended resolution
Posted on Dec 25, 2012
5 Suggested Answers
SOURCE: hdtv stb issues hdmi - dvi for Acer AL2416W
Buy a name brand STB !
Posted on Apr 15, 2008
  • 10 Answers
SOURCE: no signal from ps3 to lg tv via hdmi
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Posted on Aug 20, 2009
  • 6 Answers
SOURCE: hdmi sockets read "no signal
ur hdmi input is broke
Posted on Oct 10, 2010
SOURCE: i have plugged my hdmi
hi,
Welcome to fixya! here's the thing with this no signal issue on your TV hooked up on an HDMI try to double check physical conenction and make sure your on the right input, say for ezample if it is hooked on HDMI 1 input should be set as well on HDMI 1.
Hope this would help you
Thanks
Posted on Apr 12, 2011
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
Whether I am playing a game or watching a movie, my PS3, plugged into my SAMSUNG LCD tv via hdmi cable, will sporadically lose signal at least once every 20 minutes. The TV will go black indicating weak...
if you are facing problem in psp then just don't worry........... you can fix it with the help of repair guide you can download it and solve your problem easily...........
i will give you the link to download i hope it will solve your problem.......
click here to download repair guide
Dec 20, 2010 | Sony Playstation 3 (PS3) Console
I had my ps3 hooked up through a HDMI plug and I swithed tv's, now I have no video with the HDMI plug or the red, white, and yellow. Please help!
Hi, The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings,or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Have no visual display from hdmi - only sound
The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings, ... Or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV SAYS "UNKNOWN SIGNAL" AND I CANT GET ANY VIDEO OR AUDIO
The cord may have a short in the wiring. A pin in the connector could be missing. Or the PS3 hdmi socket could be bad. You should call Playstation Technical Support line at 1-800-345-7669 (1-800-345-SONY). If it under warranty you should not try to fix this problem yourself as you could cause even more perment problems.
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
