Question about Fisher Price Toys
Music Box Record Player.....have taken it apart without any problem....sprayed metal parts with WD 40...this loosened the parts and now they can be turned with my fingers...winder button now makes a ratcheting sound which it did not before.....however the spring apparently never tightens...I suspect the spring inside is broken...any suggestions?
    Sergeant:
  • 378 Answers
WD40 leaves a residue behind to help prevent moisture. Unfortunately, the residue can gum up the internal workings of some items and prevent them from functioning properly. I'm afraid that you are right and that the spring may be damaged. Weather this is from the WD40 or not, I don't know.
Good news though, is there is a group that repairs old toys. Their web site is http://www.thisoldtoy.com/l_fp_set/toy-pages/900-999/995-musicboxrecordplayer.html
Toward the bottom, you can reach them by email and arrange to have this repaired through them.
As a rule of thumb, don't use WD40 if you want it to work next week too. The chemicals in it end up gumming up the inner workings. I've used WD40 as a cleaner when I need to remove rusting. When something requires light oil, a good 3-in1 oil is best.
A bit of trivia for you - WD-40 stands for Water Displacement, 40th attempt. Makes you wonder, if they would have gotten it right on the 39th attempt, they would have called it WD-39???
Good luck,
Mark
Posted on Apr 02, 2011
My indicators and horn are working intermittently
Check the earth terminals on the horn and indicators. Too much WD40 doesn't help either, you only need to wipe the terminals with a wetted rag of WD40, and used emery paper to cut back to bare metal for a better contact.
Feb 07, 2015 | Honda CBR 600 RR Motorcycles
Tip
I Want My (Digital) Rights!
In 1958, the Rocket Chemical Company realized that selling WD-40 for public use as a lubricant spray could be a very profitable endeavor. Today, WD-40 widely available in hardware and discount stores. There are five delivery systems for the product: WD-40 aerosel is the traditional delivery format; the WD-40 Smart Straw is a can with a permanently attached straw; the WD-40 No-Mess Pen allows you to use the product while on the run; WD-40 bulk/non-aerosol is offered in gallon and 55-gallon containers for large jobs; and the WD-40 Big Blast provides a wider spray pattern and larger can size.
Although WD-40 has a very distinctive smell, there is nothing dangerous in the product. The odor is simply the result of a fragrance added during the manufacturing process. The primary ingredients in the product are mineral spirits, liquefied petroleum gas, and mineral oil. The exact formula of WD-40 is a highly guarded trade secret, however.
For automotive repair, WD-40 has many uses. It can drive moisture out of the high- and low-tension electrical components of a motor engine and loosen nuts or screws. If you're trying to keep your car in top shape, WD-40 is also good for restoring and cleaning padded leather dashboards in vehicles.
Around your home, WD-40 can fix noisy door hinges, keep scissors working smoothly, loosen rusted screws, stop electric fans from squeaking, and lubricate the tracks in your windows to make them easier to open. Many people also report that spraying WD-40 on hand tools is a good way to prevent rust damage. Although it seems hard to believe, WD-40 is also a great household cleaning product. It is good for removing lipstick or tomato stains from your laundry. You can use it to remove stubborn duct tape residue, clean splattered grease off your stove, keep glass shower doors free of water spots, clean stainless steel sinks, and camouflage scratches in ceramic or marble floors. WD-40 will even take oil spots off concrete driveways.
dont remember to rate this tip...
thank you !
on Aug 16, 2010 | Audio Players & Recorders
Tip
What is WD 40 ?
on Aug 14, 2010 | Price Pfister 43-OOXC Bathroom Faucet,...
I have a pressure washer at work that has good spark and starts when I put gas in the carburetor.But it wont stay running. I have the gas turned on but it doesn't seem to be getting to the carb. It's...
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Nov 22, 2010 | Honda Pressure Washer PSI 3000
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
Kia ora, i have a makita 2 stroke grass cutter, that just wont start, checked, spark plug, fuel, took it apart and cleaned it..still wont start. Please help, it does not have model number only product...
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
Oct 08, 2010 | Makita Garden
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Rear brake handle or cable seized. Cycle not used for some years. Rear brake caliber appears to be working fine.
unfortunitly when bicycles sit the cables tend to rust inside of sheathing. you can try to spray a good lubricating oil into cable like wd-40 and try working cable free but my experience has ben that it is usually easier to replace siezed cables with new ones.
Aug 19, 2009 | Cycling
It keeps sewing after the foot petal is let off - sews like crazy without me touching it!
Sounds like the foot petal needs to be taken apart and cleaned. Make sure everything is unplugged. Use WD-40 on everything except any electrical parts, it has chemical  agents in it that break down the plastic after a long period of time.
Jul 31, 2009 | Sewing Machines
How to open FP music box record player, #995 or #995N
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
Jan 08, 2009 | Fisher Price Toys
Toys Logo
135 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
