Question about Cub Cadet Garden
I have a 1554 cub cadet and it seems like its flooding out. choke is not on. put in new plugs fuel filter air filter clean carborator and still the same. can you help.
  • 608 Answers
Check oil is not diluted with fuel. (smell it)
Posted on Apr 11, 2011
My cub cadet modle LT1045 doesn't seem to be getting gas. The fuel filter looks clean. If I spray gas directly into the carb it runs fine but as soon as I stop it dies.
Confirm that the choke is closing completely., Check that the fuel pick up hose does not have a air leak. Confirm that the vent hole in fuel cap is not plugged.(common problem)
Remove fuel line hose to carburetor catching fuel output in a suitable container crank engine and confirm fuel pump is working.
Remove fuel bowl and confirm needle valve is not stuck closed.
Hope this helps?
Fuel Pump
Needle stuck closed
ca4f54cab4d4c1bb583599b331fd2337--small-engine-repair-lawn-mower-repair-u3ralalmkh2yk13xn5gn3lpt-2-2.jpg Check fuel filter
Check vacuum line connection for leaks.
Jul 01, 2017 | Cub Cadet Garden
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
Wh;y does my cub cadet 1554 tractor mower lose power when engaged?
  • Does deck turn freely? Check and be sure mowing deck is not jammed or bad bearing etc. If nothing is wrong with deck, then check fuel filter, air cleaner element, dirty fuel system, bad gas, water in fuel, restricted fuel flow. Lack of fuel will cause engine to have lack power.
Aug 15, 2014 | Cub Cadet Garden
Cub cadet 1554
Is there anything wound around the motor shaft? If its belt driven is the belt loose or tensioner bad?
Aug 15, 2014 | Garden
I have a kohler 18 hp twin engine on a cub cadet. Backfire when shut off. Started back up sputtered. Fuel coming out by air filter. Took air filter off and ran great. What would be the problem?
Check to make sure idol isnt set too high, make sure the air filter is infact clean to prevent it from chocking itself, make sure choke is off :-) and also make sure you idol all the way down when you kill it. Make sure your spark plug is good to prevent flood, and detonation, peaceout.
May 05, 2014 | Garden
1050 Cub Cadet
Fit new spark plugs and new fuel filter.
Jan 09, 2018 | Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Loses power while mowing
that wont cause your mower problem i think you have a dirty carb and fuel filter clean the fuel tank to put new gas from clean can in but to check charg system get voltmeter start engine let it run un hook positve side of battery put the red led of voltmeter on positive side and the black led to the negative side of battery and see how many volts produce 12 to 13.5 good below that replace regulator above that replace regulator
Jun 18, 2013 | Cub Cadet Garden
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Garden Logo
211 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
