Hi i have a simple comfort AM7890-DHW thermostat and my condo is just cooking. I know that the two settings are for heat and cold to kick in and i have them set properly but it still is not fixing the problem. I tried holding the program and mode button and fooling around with these settings but i don't know what any of the abbreviations mean so i cannot fix anything. Is there a way to program it to cool off this condo. Thank you
We're having exactly the same problem. I called ICM at 1-800-382-3113 and asked for tech support and they emailed the 2-page manual right away. I talked to Eric Wood, an Electrical Engineer there, and he sent it immediately. I hope this helps!
Posted on Apr 07, 2011
  • 2 more comments
  • klawzeus Jan 24, 2012
    big no on the 1-800 number. I just called them and asked for the manual to be emailed to me, and the response was "We don't have anything to do with Simple Comfort thermostats, and I dont know why our name is associated with them at all."
    still searching for the manual for this hardware.
    the number for ICM is 1-800-365-5525. They are emailing me the manual as I type this out.
  • overtime85
    overtime85 Apr 22, 2012
    can anyone share this manual? my email is noelbroughton@hotmail.com.
    Thanks!!
  • Seanna pascal May 21, 2012
    Could I get a copy of the manual as well please? pascal_seanna@yahoo.ca
Our unit is in cooling mode but blowing warm air, what can we do to correct this
Posted on Aug 18, 2011
    Same : ( I have mine set as 7C-H and 21C-C ...is this correct in order to cool my apartment down?
How do you program a simple comfort AM7890-DHW thermorstat
Have you already searched the manufacturer's website?
Jan 16, 2013 | Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Good day! A condo suite has a programable digital thermostat operating on 24v for heat (geothermal heat pump solenoid valve) ac, and a humidifier to control. When the humidifier kicks the fan coil...
Hi, start at the thermostat on this unit if nothing else has been done as far as trouble shooting and repairs. 3 months doesn't mean a thing when it comes to a/c and refrigeration & heating parts. Check the stat operation, or replace it, and I am 99.9% sure this will solve your control problems.
Sincerely, and a good day to you!
Shastalaker7
A/C, Heating & Refrigeration Contractor.
Feb 09, 2011 | Heating & Cooling
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Switching thermostats
The two wires are the control circuit from the heater your running. They go to the thermostat and close when it get below the thermo. setting and start the heater.
Jun 28, 2009 | Honeywell Electronic Programmable...
Can not figure out how to control thermostat
If you take off the front control panel cover (simply prying off on the edge with finger) you will find 2 small buttons under the display panel, one being mode and the other being prog.
Press both simultaneously and hold down for 5 secs and the display will blink, press prog to advance to what you want to program, kinda like setting a timex watch. As I recall you can set degrees celcius or farenhight/ cycle/Hi/Lo etc.
Just keep in mind when you set using the up and down arrows:
flashing H means: at what temp do you want HEAT to kick in?
flashing C means: at what temp do you want AC (if you have it) to kick in....if no A/C fan simply blows air.
Hope that helps.
May 03, 2009 | Heating & Cooling
Thermostat location on York Diamond 90 gas furnace
Augold, sometimes its best to set the thermostat where you "feel comfortable" . I.E. set it and leave it til you feel the need to be cooler or warmer.
A thermometer on a thermostat will not always be accurate and setting it will only get it within 2 to 5 degrees which is enough to "feel".
Now from the stand point of is it working properly????
Assume you feel comfortable and the heat stays on to keep you comfortable is their anything wrong with this? I assume this is the goal. Even if it says 90 (and you know its not 90) and your comfortable you could leave it alone and be OK. If this kind of thing is whats bothering you a new thermostat may not be much better, unless your ready to invest in one and accept it however it should be closer to the place youd set it. Id recommend an electronic type they are more accurate and level doesn't matter so much to these types.
If you want to set the temperature and are determined to go by a thermometer to "feel Comfortable" I recommend you buy an electronic thermometer and set it close by the thermostat. Make sure you have no lamps or other heat sources close to the thermostat area.
Remember the far end of a room or a chair by a window Especially with little or no curtains and on the prevailing out door wind will always feel colder and be colder than the area by the thermostat even if both are in the same room. If your too cold try running the thermostat up a few degrees. If too warm set it lower. The equipment doesn't care how cold or warm it is.You will not increase your utility bills to the national debt by being comfortable
If this helps please grade me accordingly and Good Luck.
Mar 03, 2009 | Weather King 10AJA3601AH Air Conditioner
Honeywell T8400B Thermostat Display Intermittently Blank
most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
2,354 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
