Question about Dewalt 18 Volt Compact Drill Kit
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
    Problem Solver:
  • 17 Answers
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Posted on Apr 06, 2011
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Drill bit falls out , cannot use reverse to extract srews or bolts
are you installing the bit correctly. is the chuck defective... is the a name for the product. does it have a keyless chuck... are you inept ???
Oct 24, 2013 | Dewalt 18 Volt Compact Drill Kit
I can't get the the drill bit out of my cordless drill
Try to keep your drill straight and try a bit harder - looks like you were drilling something very heavy.
Apr 03, 2010 | Dewalt 18 Volt Compact Drill Kit
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
I have an 18 volt 1/2" drive cordless impact wrench made by DeWalt and when I pull the trigger the motor runs but not the anvil?
Sounds like you have a gear broke that runs from the motor to the shaft. Take it apart and check it out. easy to put back together. atleast you will know for sure and may fix it while it's opened up.
Jan 18, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18v cordless drill question
yes this is normal the spark keeps motor from stalling out by taking away the friction spark by making own spark
the clunk is the drill brake so you dont brake your hand when screw goes in all the way unlike old drills that kept going even when your hand was attached to it
Jun 05, 2008 | Dewalt 18 Volt Compact Drill Kit
My dewalt drill won't drive
is your battery is fully charge or maybe your clutch setting are too low. set it drill mode if it is not working you need to replaced
trans/clutch assy
May 28, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
210 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
