Question about Beko 324250WN 28" TV
Beko 32wlu530hid keeps freezing everytime i try to change channel.have to shut tv down then turn it on again, sometimes tv stays on 20 secs - 20mins but then freezes without even touching the remote to change channel. what can i do with it, please help
  • 577 Answers
H?,
This problem unfortunately very common on these TV sets..
As far as I examine the case ,I believe a component on the circuit board is not properly working..
Either there is cold soldering on the board or a dead capacitor may cause this.
Sorry but Your TV needs service..I hope you still have warranty to cover this..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Jul 01, 2011
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Hi, My Grundig Lenaro tv keep freezing every time I try to change a channel, I have to turn it off and on with the button on the tele (not remote) to get it going again... any idea what that could be? It...
Hi. I have had the same problem for the last 6 weeks on my Lenaro 32"
Have contacted the Grundig Support and they are balaming it on the Digital Receiver. They say that the receiver component is made by Beko and thay have carried out an Over The Air upgrade which has caused this problem. Grundig contract out their services as this is just a trading name.
Their support is not willing to do anything and say that it is down to Beko.
I am now trying to get hold of Beko. After that I am going to contact trading strandards and Watchdog.
Apr 28, 2011 | Beko 324250WN 28" TV
The digital tuner on my Olevia LT37HVS LCD TV freezes sometimes. When it does, you can't change channels, adjust the volume or even shut it off short of unplugging it. All of the other A/V inputs work just...
Tune the tv to a channel that is just blue screen. Then turn the tv off and unplug for at least 30 sec. Then plug the tv back in and turn it on. Then leave the tv on the blank screen channel go into the menu and do auto cable channel search. After the search is complete try all channels. This worked for me. My tv will not scan if the tv is on a channel that comes in. GOOD LUCK these tv's are junk .
Sep 21, 2009 | Televison & Video
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Can I use parts from a BEKO 32WLU530HID TV?
I guess that the power supply is faulty,look for bad caps.
If both power supply's are the same is easy to see when both sets are open.Compare the numbers on the print.
Jul 20, 2009 | Televison & Video
Tv turned on then shuts off auto. in 15 sec.
One possible reason is the remote may have an "IR leak" where it is turning off the TV by emitting a signal of it's own.  To verify this, simply remove the batteries and turn the TV on.  If it stays on, that was the problem and you would need a new remote.  If this doesn't resolve this, try a power drain to rule out over-charged capacitors:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Mar 25, 2009 | Philips Magnavox 27MS343S 27" TV
Wont come on
Instead of just unplugging the TV, perform a power drain:
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Beko 324250WN 28" TV Logo
242 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
