Question about Sony MHC-BX3 CD Shelf System
Instantly on powering on the "push power protect" message flashes. is there any way to fix this?
    Brigadier General:
  • 8,546 Answers
More diagnosis first.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 02, 2011
Hello.. I have Sony MHCEX500 MINI HIFI Component system. There is a problem of PUSH POWER PROTECT. How can I fix it..????
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
Apr 12, 2016 | Sony Audio Players & Recorders
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
I have a Sony dvd player DAV-DZ870W when turned on it displsys the word PROTECTOR push power what is the cause of this?
Apr 23, 2014 | Audio Players & Recorders
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
Dec 20, 2012 | Sony DAV-HDX500 System
Protect message
Protect means that a fault was detected, disconnect all the speakers
and connect one at a time to find the cause.
If symptoms persist , it needs repair, output stage or power supply
circuits should be the preliminary things to check.
Sep 24, 2012 | Integra DTM-5.3 Receiver
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
My Sony DAV DZ860W shows Push Power Protection fault message
http://www.avsforum.com/t/944637/sony-dav-hdx466-push-power-protector-flashing-on-display
Feb 09, 2011 | Sony Audio Players & Recorders
Whenever i turn on my sony MHC-VX333 mini hi fi it flashes the message "push power protect"
when it display push power,this indicate an instruction to push the power button. please do so
May 17, 2010 | Electronics - Others
Protect and Push power
A sign flashed across the screen "Protect and "Push power" Please what does this mean? and what do i need to do to fix it?
Regards
Fabio Catarcione
Dec 22, 2006 | Sony DHC-MDX10 Shelf System
Sony MHC-BX3 CD Shelf System Logo
78 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
