Question about Whirlpool LHW0050PQ Front Load Washer
Resetting the wash cycle?
Can you give me some detail as to what you mean?
I have tried different washing cycles (quick wash) the norm is "Normal". I adjust the spin cycle to "Low" and wash cycle to "QuickWash" with the same results.
resetting the cycle?, I do not understand, for example, do you mean, find a reset button and push it?
What does report "abuse mean"? Abuse is a deliberate action, and I don't see anybody abusing a machine that they paid $600 to use.
Even if it was deliberate, does that mean that the owner is not entitled to know how to reset the machine?
I have asked for help on this matter before, and I got a response that had the wrong model on it, and was therefore not helpful..
Posted on Nov 20, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
How do I reset the washing program ? I tried to change the washing cycle and it would not run. Now I cannot return to the original washing cycle.
Unplug the power then plug it in again. Now select the program you wish to run and start it. Make sure the door is well shut.
Dec 03, 2014 | Washing Machines
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
My Maytag FAV6800 washer hungs part way through a cycle the timer on the front display stops at about 23 on the quick wash cycle.
Sounds like a pressure switch/ chamber issue. Check the tube is clear to the drum. (Assuming front loader?)
Apr 25, 2012 | Maytag Neptune Washer
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Aug 03, 2009 | Electrolux Washing Machines
Incorrect times on wash cycles
you dont need to reset the times, all that has changed is the soil type. in example, light, regular or heavy. that is what causes the times to change.
you just need to push the options button until it shows the type of cycle you want.
also make sure you have the proper cycle selected and then look to see what other options are selected. you just have too many options turned on, so look at the controls to see what is different then you remember.
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Wash options
If its working ,DONT FIX IT!  try not to focus on the minutes its taking,and youll be  better off.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal De
