I need a replacement belt for my turntable model# AH-035. Can you tell me where to get one?
  • 62 Answers
The company it from can help you !
Posted on Apr 03, 2011
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
Turntable turns on, but it when i press play the plate doesnt spin. i noticed it budges like a mm but definetly not working
Feb 09, 2011 | Technics SL-1200 Turntable
My turntable sounds wavy or wobbly. Any ideas?
The belt needs replacing. Assuming it's a belt drive model! When you take off the belt, please make a note of how it fits. Measure the diameter of the belt (mm) and enter it into google as: "turntable belt ??MM". You should find it. You don't have to be precise on the diameter measurements.
Aug 23, 2010 | Audio Players & Recorders
My turntable has stopped functioning and I need to replace the motor I think. Any ideas?
find out first if its a direct drive turntable or a belt driven turntable with motor,w/o a make and model number i cant tell you
Aug 01, 2010 | Microwave Ovens
Ge model JE1540GW turntable comes on with door open. Do I need a new unit? AH
i would unplug and replace that unit quickly, there is a major problem with the door swich assembly.
and could be a danger
Oct 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
Replacement belt # for hoover wind tunnel model u5750-900. original belt # 38528-035, please
your belt number is correct ending in 035. I have had luck with belt number ending in 033 also.
Jan 28, 2009 | Hoover U5750-900 WindTunnel Bagless...
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
Jan 26, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
56 people viewed this question
 Grubhead
Grubhead
