Question about Sony SDM-HS73P 17" LCD Monitor
The screen has a dark green tint and cannot be adjusted. More specifically, the green section of the RGB setting on the monitor can't be changed (the G setting is permanently gray and I cannot move to that color to adjust it, the cursor just passes over it.. Is there any way to fix that? I have attempted to set the other colors to offset the G setting, but the tint still shows, especially with dark colors. I have switched PC's and cords but nothing is working.
    Guru:
  • 811 Answers
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
Posted on Apr 02, 2011
The TV works fine but the screen is green. Color
R G B circuit transistor to be checked. This is located in the picture
tube connecting end PCB. ( Neck ) Check the transistor and its components.
Can be dry solder also!!
Jul 28, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Cannot adjust contrast or color..screen is too dark and tinted pink....
DID YOU TRY TO ADJUST THE SETTING OF your monitor? change the setting of your monitor configuration...
Sep 07, 2009 | Computers & Internet
Green tinted screen
there is a Circle of Colourfull part in the monitor. it is getting break down. need to go service.
thanks to choosing FixYa.
May 28, 2009 | Acer X193W LCD Monitor
50 inch samsung tv has red tint n dis colored
Hi
please try to reset the color settings then hit the tint color adjustment, if nothing change, you have a problem with the RGB Section that is need to replace some small parts!
Thanks!
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Monitor colorization problems
1.) Check to see if the screen has a peel-away, cellophane type shipping protector on it ( transparent with a rose color tint ? ). 2.) Click Start >> Control Panel >> Display >> Settings >> Advanced. If this section has a tab labelled "GAMMA", you can manually adjust all display settings. 3.) If no gamma control is available - download one FREE ( Dark Adapted ) here >>
http://www.aquiladigital.us/
Dec 25, 2008 | Computers & Internet
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
G2 alignments?
Hello YankeeTwidgt,
Here we go you will need a schematic diagram (You may already have one but I thought I would mention it ), an oscilloscope, a TV signal generator (NTSC color bar, RGB purity screens, and pattern screen), and a voltmeter (I would prefer you have a VTVM, but a digital meter with high impedance (>=10M) will be ok).
First turn all of the color and tint controls completely down (This includes the main color and tint and the pre-amp color controls if you have access to them).
Then turn the RGB pots fully counterclockwise.
Once this is done connect the signal generator set to channel 3, and set to the specifications on the schematic, use the color bars, what you should see at this point are bars of various shades of gray.
Then turn the generator to the purity setting and set the pattern to red.
Once this is done your screen should be dark or dark red, gradually adjust the R pot until the screen is pure red and the voltages, and signals match what is seen in the schematic (mark this point on the pot and the return the pot to fully counterclockwise).
Do the same for the Blue and Green Controls (Blue first and then Green).
Once all of the pots are marked and turned to counterclockwise, set the pattern to gray purity, and turn the pots back up to their marked positions, the screen should be gray. switch to color bars and the screen should have the proper colors.
This is a course adjustment, and you will have to do a fine adjustment using the schematic, and the test tools, but this will put you way into the ball park.
The reason these pots are not talked about in gray scale adjustments is because they usually don't have to be touched. That's why it is important to get them back to specification using the voltmeter and oscilloscope to set the signals up properly.
I wish you success,
Shuttle83
Jul 27, 2008 | Philips 51PW9303 51" Rear Projection...
Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
193 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
