Question about Ingersoll Air Tools & Compressors
Randomly tripping by giving the alarm as "HIGH AIREND TEMPERATURE". Screw compressor of capacity 9.3M3/hr.
    Problem Solver:
  • 5 Answers
DEAR FRIEND
THIS IS A VERY COMMON FAULT THAT APPEARS ON THE PLC,BUT YOU SHOULD CHECK THE BELOW MATTERS:
1- IS THE ENOUGH WATER GOING THROUGH THE COOLING SYSTEM AS REQUIRED.
2-IS THE THERMOSTATIC VALVE IN THE OIL CIRCUIT DOING OKAY?
3-THE QUALITY OF THE OIL,WHEN IT HAS BEEN LAST CHANGED,THE OIL FILTER AND ......ALL CONSUMABLE COMPONENTS NEED TO BE CHECKED
4- IT MAY BE AT LAST THAT THE FILLER BETWEEN THE TWO SCREWS ARE WORN OUT AND BECOME LOOSE(I MEAN THE SCREWS OR THE BEARINGS),THUS BY A SIMPLE OIL ANALYSIS IN A LAB IT CAN BE DETERMINED.
SO IF YOU ARE READY TO APPLY GO ON STEP BY STEP
YOURS FRIENDLY
IMMAN OSTOVAR
Posted on Apr 05, 2011
Ingersoll rand compressor model no 75i high airend discharge temperature trip why
Wash the cooler first. Then replace thermostat if washing cooler d't take care of the problem.oesn
May 08, 2017 | Ingersoll Rand Air Tools & Compressors
7.5 tas high airend temperature
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Aug 29, 2012 | Ingersoll Rand Rotary Screw Compressor ...
My air compressor show continusly the alarm NO CONTROL POWER
No Control power is often caused by high airend temp or a faulty High AirTemp. switch(IATS Switch i.e High Air Temperature Switch). I suspect the IATS switch is bad and opening prematurely/coolent level not suffecent or bad filter condition because the att. temp. probe located next to the switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power and series to emergentcy switch having two NC connection but if press emergency it gives alram emergency but if you remove cable 36 inintellisys control pannel. Thus the controller issues a No control power . This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jul 04, 2012 | Ingersoll Rand Air Compressor Maintenance...
Ingersoll rand air compressor model SSR-UP5-30-14 frequent trip on high airend temperature ....what is the solution ? and another unit ( same model ) always trip on " starter fault ". Untill...
check if approach and discharge pipes to oil cooler are similar temperature as there is a thermo bypass valve that controls the flow through the cooler if cooler is quite cool but still very hot inside this could be stuck in closed position causing restricted flow through the cooler
Sep 20, 2011 | Ingersoll Air Tools & Compressors
Frequent alarms "Control power loss" Often
Control power loss is often caused by high airend temp or a faulty High Air Temp. switch(HAT Switch). I suspect the HAT switch is bad and opening prematurely because the att. temp. probe located next to the Hat switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power. Thus the controller issues a control power loss. This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jun 08, 2011 | Ingersoll Air Tools & Compressors
We have an Ingersoll Rand- 100hp air compressor. We only run this periodically- when we have a power curtailment and trying to reduce power consumption or if our primary air compressor faults out. When...
replace the hat switch. hat = High Air temp. This switch is located on the end of the air end and usually has 1/2" flex conduit on it. Remove the conduit. It goes to a box located on the frame near and under the airend. Remove the cover from the box tug on the wires at the hat switch to see which two wires need to be disconnected.disconnect wires unscrew hat switch. Put a new oring on the new hat switch and install new hat switch. Hat switch is the only switch that will give high temp and lose control power. Let set a while and can reset unless probe is broken off.
May 31, 2011 | Ingersoll Rand Stationary Air Cooled...
The compressor is mechanicaly bloqued and belt broken just 30 seconds after statrup.
Check airend and motor to make sure they rotate freely, no binding, or rough places in the bearings. If this unit has just been installed motor rotation may be incorrect. 3phase power rotate (move any two incoming power leads). If single phase you will need to open weather head of motor and rewire per motor data plate. If motor or airend are binding or locked up they will need replacement or repair. If the unit has been running and has not been recently installed I would start at the min. pressure check valve located on top of the seperator tank. If this valve is bad it will let system pressure back to the airend. the unit may or may not start if this has happened. they trip breakers,break belts, trip overloads etc.
Apr 18, 2011 | Ingersoll Rand Stationary Air Cooled...
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
94 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
