Question about Garden
The recoil rope will only pull out about 5" and stops dead. No obstruction in shipper. Blate turns. Tecumseh 8 hp. Thanx!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Sound like your engine may be tight. Make sure that the belts are loose and attempt to rotate engine crankshaft at pulley side of engine using pliers to get a grip on shaft. If shaft will rotate problem is in starter pull rope mechanism. It engine is tight you must seek professional help or you may damage engine further by forcing engine to move.
Posted on Apr 04, 2011
  • richardhgold Apr 04, 2011
    Thanks for the tip! The shaft will rotate but not when I pull the rope. The rope only pulls put about 5" and stops DEAD. I suspect the starter rope mechanism. Is this fixable? I have a MTD model # 465A Chipper/Shredder. It is only a few years old. It was running fine until I shut it off this weekend and then the above rope problem started. Thanx!
    Ricky G
    Apex NC
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Tecumseh HM80-What length of pull rope do I use for replacement & where should the choke lever be set once the engine warms up, all the way to the right or on the first bump (detant?)?
the replacement pull rope for the motor will be the right length if you buy a genuine pull rope or a rope that is for your machine. The choke should be in the full open position when warm
Jan 11, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Snow blower recoil rope broke tied back up and now will not recoil
    Unless the recoil spring is broken, then you may have neglected to pre-load the recoil spring. With the recoil unit off of the motor, wind the rope fully around the pulley. Then, while keeping the rope fully wound, turn the pulley about 5 times around in the direction that would push the hope out through the hole. At this point the recoil spring will be trying to spin. Without losing that tension, push the end of the rope out through the hole, thereby putting a bit more tension on the recoil spring. Tie on the handle. Now, when you let go of the rope, the spring should hold the handle snug against the hole. An alternative method is to use a rope about 2 to 3 feet longer than the original. Wind it fully around the spool and put the end of it through the hole. Now pull the extra length through the hole until the tension is sufficient. Cut off the extra length and tie on the handle.
    good luck, Al K
    Jan 11, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Ariens 8.5 HP snowblower, 5 years old, recoil starter will not let me pull the rope out and the electric starter is not engageing, thoughts?
    First I would take out the spark plug then try tugging on the rope. If no success take a ratchet and a deep well socket that fits the nut on the flywheel tighten and loosen the nut with out restricting the flywheel does the engine turn over? Does it move then stop after you loosen the nut? If it does then check the oil. If it is low or none in there then the motor froze up and needs replacement. If this was no help check in the shoot for obstructions like a newspaper stuck in the auger or the thrower.
    Terry
    Jan 10, 2011 | Ariens Garden
    How do I replace the pull rope on my bl100 trimmer? I know how to install it just not how to get it to rewind.
    You are going to need to "preload" the spring in your recoil/starter unit BEFORE you install the pull rope. Turn in in the direction where you feel it becoming tighter. Turn it about 5-7 revolutions. Don't get carried away and make it REAL tight as you will break the spring steel recoil spring. After you have it set, jam it or hold it with vise grips or a screwdriver or with your hands and have someone install the pull rope. Make sure the handle is installed on the end of the pull rope before you begin because when you let the recoil pull your new rope in the handle will stop it. There should be a little bit of tension left on the pull rope once it is drawn in all the way.
    Oct 31, 2010 | Garden
    Repair of pull start to garden blower
    To replace the pull cord line:
    If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
    1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
    2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
    3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
    4. Cut the line and pull the knotted terminating end from the hosing.
    5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
    6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
    7. Remove the wedge and allow the spring to pull the rope back into the recoil.
    8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
    Sep 25, 2010 | Garden
    PULLED ROPE AND HAND SLIPPED OFF NOW THE ROPE WON'T RECOIL ALL THE WAY BACK INTO ENGINE. RECOILS ABOUT HALF WAY. WHAT SHOULD I DO TO FIX THIS PROBLEM?
    Play with it ... My Tecumseh does the same. The little catches inside dont always catch like they should. You can remove it and fiddle with them like I did ... it will work for a while and go bacl the the 1/2 trick. You can replace it ... and it will be ok for a while ...
    I have learned to live with it ... my tiller is 1977 model
    Oct 26, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Recoil rope won't recoil!
    -In bnjays case the rope was broken. Sometimes the rope retracks partially or slowly because the surface that the spring edges rub against when retracting the cord, are badly rusted. Disassemble and wire brush the rust off, or leave assembled and spray in thru holes in the pull start with WD40.Avoid getting WD40 on the rope.
    Feb 18, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Rope snapped in my recoil starter..
    take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
    Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    Garden Logo
    269 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
