Question about Maytag Dryers
No heat to dry clothes i checked breakers they are on
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/.././/.
Posted on Apr 03, 2011
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
My dryer doesn't dry. I checked all of the vents and they not clogged. I checked the vent coming out of the dryer itself and their is hardly any air coming out What should I do?
Try resetting the double pole breaker. Sometimes on a 2 pole circuit breaker one breaker will trip allowing the dryer to run but will not produce necessary heat to dry clothes in a timely manner.
Feb 27, 2011 | Maytag Dryers
My dryer we've had for about two months won't dry clothes. it heats up, but they are still wet four cycles later
I was thinking you have a bad circuit breaker. This dryer runs on a 2 pole 30 amp 240 volt breaker. The motor runs on one side of the breaker on 120vac. The heater has to have 240 volts to work correct. When that breaker is on the way out it will take a new dryer 3 or four times as long to dry the clothes. themobilian_294.jpg
If you are cleaning the lint filter out and don't have a clogged vent pipe themobilian_295.jpgthen in my opinion you have a bad circuit breaker. Seen it.
Nov 27, 2010 | Amana NDE2335AY Electric Dryer
My dryer is making too much noise and it's not even drying up clothes.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 12, 2010 | Frigidaire FER311FS Electric Dryer
Clothes don't dry completely
Check your breaker. An electric dryer works on 220 volts, which is two 110 volts put together, but on separate lines. Those breakers have to be separated all the way from the transformer. So, if you have one breaker for the dryer, you will be okay, usually on a double pole, double throw breaker. Sometimes they are wired into two different breakers. The motor is on one breaker, and the heating element is on the other breaker. So, if they aren't on a breaker that is made as a double unit, the heating element can trip one breaker, and since they aren't made together as a unit where it will shut the whole dryer down, the motor in the dryer will still run, and the drum will still turn. It just won't dry clothes. Now, if you have made sure your power is ok, which i have no way of knowing if you just moved there, you had the dryer working in that spot for fifteen years, or what. So, if you have had it there for a while and it runs and it does not dry, and the breakers aren't tripped, then you need a new heating coil in the dryer. They burn out, just like toasters go bad, they work on the same principle. It is not that hard to replace one, just look at how the old one is before you remove it, and install the new one in the same way.
Jul 11, 2010 | Kenmore Dryers
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Whirlpool dryer heating, but not drying
hi..you probably have a tripped electrical breaker.
check your breaker box first and reset any tripped
breakers.If that doesn't work,you may have to replace
the heating element.
check it out..
thank u..
kindly rate my response..
May 17, 2009 | Whirlpool Dryers
When we turn on our Kitchenaid dryer it squeals and it won't dry the clothes. No heat. thanks
the squeals could be the belt giving out. and with no heat i would check limit switch and or the heating element. also check and make sure your house breaker has not tripped. on most dryer they are ran on 2 breakers.
Aug 22, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
