Question about Bosch Washing Machines
I have a Bosch WFL2090 washer. Was making a terrible grinding noise and now the drum will not turn. Water pumps in and drains out. Where do I look next?
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 125 Answers
SOURCE: Nasty Noise when Maytag MAH-24 pumps-out
Unplug the machine. Tip the machine back. Take the plastic cover loose from the bottom front of the machine. There are 4 screws on the right front side of the machine that form a square. Remove those and take the spring clamps off the pump hoses and wire connector. Whatever water that is in the machine will come out, have a bucket or shop vac ready. The coins or other foreign objects that are in the pump can now be removed. Hope this helps
Posted on Jan 13, 2008
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
SOURCE: washer is leaking
My washer is leaking from the same area of the drainage pump but it's leaking even before the pump turns on. Any ideas how I could fix this? Thanks so much!
Posted on Feb 24, 2010
Hi there! I have a Frigidaire Gallery GLGH1642FS1 stacked washer/dryer. Its making an awful grinding noise while trying to pump water out...the drum still seems to be turning though...any suggestions? Do I...
The washer is separate from the dryer as far as the systems go. It may be possible that you accidentally unplugged the connectors to the water hot valve when doing your repair.
The pump is probably the problem with the noise you describe. if the washer has a belt under the washer it is common for these pump bushings to go bad and make a grinding sound. There could be something stuck in the pump also.
Jun 25, 2014 | Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Water filling grinding noise
It may be teh Pupmp. Teh pump always turns on these units. They either pump water out to the drain or recycle it back to the drum. It sounds like during the Fill cycle, you have the Pump fins hitting.
Dec 13, 2012 | Kenmore Elite HE5t Washer
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain. Makes grinding noise
check your water pump. there maybe something in it. If there is you may have to replace the pump
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
