Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer saying .f 51 - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 6,784 Answers
HI
This will be a strong indication of motor rotor position sensor (RPS) failure. This sensor records rotational speed. It will most likly need to be repositioned, or replaced.It is mounted just to the side of the stator
Posted on Apr 02, 2011
What does code f 51 mean
Here are available manuals:
https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
You will want to look at "owners manual" and "parts list." Not sure why each category has four PDF versions available. Although the owner's manual does not address the specific code F 51 it does say this in the troubleshooting section:
F_ _ "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
Jan 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
My washer is saying F-51
This seems to be a common problem. If you hit stop/start each time the washer stops, the washer will continue further, allowing you to get through a load, but that is a temporary work-around.
You will need to contact the service department, and they will replace parts to fix it. One person had success with opening the control panel and reseating the connectors.
See this thread for more information.
Feb 12, 2012 | Whirlpool Cabrio Washing Machines
The winscreen wipers on my vw polo (51 reg) have started coming on randomly. They then don't turn off until they are good and ready. Embarassing to say the least. What is the likely fault and is it costly?
when you use the washer function of the control arm you also turn on the intermitant wiper function,you need to quickly press the washer setting to switch it off.(bloody clever these VW designers.....)
Aug 20, 2010 | 1991 Volkswagen Fox
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer fills up and then displays an "F" then 51?
May be the pressure starter is faulty kindly replace the pressure starter the problem will be solved
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer says f 51?
The F-51 code is one of the consumer headaches that have hit Whirlpools product lines. I've had to replace many a sensor and or control board to correct this problem. The problem rests with the software/ sensor combination that monitors the agitation of the washer. Theres nothing you can do about it except have a reputable service person diagnose it. Hopefully your washer is under warranty, it can be expensive.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I keep getting an F 51 error code on my washer?
if not under warr. You must replace sensor on bottom of tub along with the wiring harness. This is a common problem with these.
Oct 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
