Lexmark x4650 hi, I have plugged a in the printer, nothing happening at all , no indicator lights, it has suddenly died , last used it a couple of weeks ago , any suggestions ? thanks
  • 24 Answers
Verify that the power cable is firmly connected into the printer. Plug the printer in to a different outlet, one that you have confirmed works (plug in a lamp to verify that the outlet works). You may plug in the printer without the computer connection to test this. Check to see if the printer has an additional power switch on the back near where the cable attaches. If the problem persists, verify that the voltage is correct with a multimeter. The output voltage should correspond to the DC Output value written on the adapter. Confirm that this voltage matches the DC voltage required by the printer as written on the underside model placard on the printer. If the voltage is incorrect and the adapter is the correct one for the printer, replace the power adapter. If the voltage is correct then there is a problem with the printer that requires repair service. You may want to consider a new printer if this one is not covered by your warranty.
Posted on Apr 02, 2011
Carrier Jam message in window
http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Jul 21, 2012 | Lexmark X4650 InkJet Printer
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 24, 2012 | Lexmark X4650 InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
My printer keeps missing some letters or words
What is the operating system of your computer? Does this happen to all print jobs you send to the printer? Does this happen to all applications you're using on your computer? This could be driver issue. Try to use the updated Lexmark X4650 driver from the Lexmark website at http://bit.ly/iofMNC.
May 09, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Need illustration of everything that should be plugged in on the Lexmark X4650. Have been fighting this thing to get it to print, for the last week. Thanks.
There are 2 connections that are needed to be done on the printer. One is the AC adapter and the other one is the USB cable that connects to the computer.
mariolands_7.jpg Also you can read about setting the printer up in the User Manual: http://www.lexmark.com/publications/pdfs/2007/4650/v12364191_en.pdf
And you can read here about Wireless Setup.
Dec 02, 2010 | Lexmark X4650 InkJet Printer
Lexmark x4650 cartridge problem
maybe your ink is empty. you need to change you cartridge
Feb 25, 2010 | Lexmark X4650 InkJet Printer
X4650 help
please follow the link below to download the driver for your printer directly from Lexmark.
For Lexmark http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to select your exact model and operating system.
Sep 28, 2008 | Lexmark X4650 InkJet Printer
k24674
