Question about Garden
NEED CHARGER ALLEGHENY IMPACT WRENCH 24 VOLTS CIW 114 GIVE ME ADDRESS TO GET CHARGED PLEASE
4 Suggested Answers
witmoz
  • 390 Answers
SOURCE: I have an Allegheny 24 volts combo tool set that
you can order 1 from black & decker ,from ther website or by phone.or in some cities they have stores.or try battery depot.
Posted on Sep 03, 2010
SOURCE: I need a replacement 24 v battery charger for my
Call Alltrade customer service representatives at 1.800.423.3598. they own Allegheny. have model number ready
Posted on May 25, 2011
  • 75 Answers
SOURCE: Where can I find a replacement charger for the
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Posted on Aug 21, 2011
I have a 24v cordless impact wrench i dont have a charger can i put hot and a ground wirl on it to charge it i
Call Alltrade customer service representatives at 1.800.423.3598. they own Allegheny. have model number (CT 120-C) ready
Jun 05, 2011 | Impact Allegheny 1/2'' Drive 24v Cordless ...
The battery has full charge but the impact wrench will not work i got 26.3 volt on the battery what wrong
Did you but it new? How many batteries do you have? have you had shorter and shorter batteriy life?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 13, 2010 | Impact Allegheny 1/2'' Drive 24v Cordless ...
I need a replacement 24 v battery charger for my Allegheny power tool set Model CT120-C. Where can I find one?
Nov 22, 2010 | Black & Decker Hand Tools
I work at a homeless clinic. We had a Jazzy 1170 donated and we charged the battery for about 7 hours. When we tried it out it moved very slowly. Nothing was registering on the amp meter on the back. ...
Yes you probably need new batteries. If you have access to a digital voltmeter set it to 200 volts DC and plug the leads into the charger port located under the front of the joystick. Plug it into the 2 outter holes. Without the charger plugged in you are reading the battery voltage it should read 24- 27 volts. Now plug in the on-board charger and the voltage should go up to 27-30 volts. If you don't get at least 24 volts w/o the charger plugged in then the batteries are bad. If you don't read 27-30 volts with the charger plugged in then the charger is bad and unfortunately both might need to be replaced. Hope this helps
Sep 14, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
I have an Allegheny 24 volts combo tool set that is missing a rechargeable battery and charger. Where can I get the battery and charger? Thanks Sal
Aug 22, 2010 | Black & Decker SZ360 Cordless Power...
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Charging the battery is useless every time!
I HAVE A ALLEGHENY 24 VOLT IMPACT WRENCH THE CHARGING STAND IS BAD HOW CAN I GET ANOTHER ONE OR CAN YOU TELL ME HOW TO CHARG THE BATTERY?
Nov 09, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
